This is one of those situations where it is helpful to extrapolate to the most extreme possible cases.
Imagine an aircraft in a descending turn, with the descent path incrementally getting steeper and steeper. I.e. the glide ratio is incrementally getting poorer and poorer. The flight path is incrementally getting closer and closer to a vertical rolling dive, with the direction of the roll being toward the lower wingtip.
In less extreme cases, when the flight path is below horizontal, but not yet vertical, note that a non-zero roll rate is needed just to maintain a constant bank angle, with the direction of roll being toward the low wingtip. If the roll rate decreases below the required value, the bank angle will decrease.
At the extreme limit case where the flight path truly is aimed vertically downward, the wing is generating no lift, and the aircraft's weight is entirely supported by the drag vector. In this case turn radius is zero, and the bank angle is undefined, and the roll rate is no longer constrained by the dynamics of the turn. The pilot can set the ailerons to any position he or she desires, and the roll rate will be limited only by the aerodynamic "damping" effect in the roll axis.
Note that if the airspeed is stipulated to be constant, then as the flight path gets progressively more vertical, the component of the airspeed vector which is tangential to the circle of the turn-- i.e. the horizontal component of the airspeed vector-- gets progressively smaller. This means that a progressively smaller centripetal force component is needed to obtain a given turn radius, and also that a given centripetal force component will drive a progressively tighter (smaller) turn radius.
Of course the situation is complicated by the fact that the centripetal force component is not constant, because as the flight path gets progressively steeper, a progressively larger portion of the aircraft weight is borne by the drag vector rather than lift vector, so the lift vector gets smaller. Still, the net effect is that due to the decreasing turn radius, the turn rate will increase as the flight path gets steeper, given the assumption of constant airspeed and constant bank angle.
Essentially all the same logic applies to a climbing turn as well. The main differences are that 1) the climbing turn, it is the thrust vector rather than the drag vector that supports some of the aircraft weight, and 2) in the climbing turn, the direction of roll required to maintain a constant bank angle is toward the high wing tip, not the low wingtip, so if the roll rate falls below the required value, the bank angle will increase, and 3) the extreme limit case is a vertical rolling climb with the direction of roll being toward the wingtip that was the higher wingtip when the flight path was less vertical. The end result will be the same-- the turn rate will be higher when the flight path is more vertical than when the flight path is entirely horizontal, given the assumptions of a constant airspeed and a constant bank angle.
In the real world, of course, the idea of using one given constant airspeed for a wide variety of trajectories ranging from vertical rolling climbs to ordinary horizontal turns to vertical rolling dives doesn't make a lot of sense.
