The specification of NOTAM is somewhat flaky. Edge cases may even be hard to parse programmatically unless EUROCONTROL guidelines are being followed as well.
For the sake of simplicity, let's assume the following examples are valid from 2022-01-01 thru 2022-01-31.
D items (which specify the exact validity periods of the NOTAM) may span across midnight as follows:
D) 01-10 2100-0600
This is to be interpreted as follows:
Valid for ten nights beginning with 2022-01-01 21:00 thru 2022-01-02 06:00 and ending with 2022-01-10 21:00 thru 2022-01-11.
So even though the dates mention only 01-10
, January 11 is also included as the times span across midnight. So far, so easy.
Things get hairy once exceptions are added to the mix:
D) 01-10 2100-0600 EXC WED
The only Wednesday in that period is on 2022-01-05. The above can be interpreted in two ways:
- On exactly 2022-01-05, the times do not apply. So the NOTAM is not valid that Wednesday from midnight to 06:00 and from 21:00 to midnight.
- The entire period starting 2022-01-05 is excluded. So the NOTAM is not valid that Wednesday from 21:00 thru the following Thursday 06:00.
I tend towards interpretation 2 since the other interpretation produces somewhat fragmented validities and I'm having a hard time imagining a situation where this actually makes sense.
But I can't find any hint about this case in the documentations. Has anybody seen such a case in the wild? Or maybe some more detailed official guide as of how to interpret such cases?
Thanks a lot!
