As you know, there are two push buttons (MASTER SW and START) related to the APU in the Airbus A320 family.
Why there are two pushbuttons? I mean is there any condition in which users switch only one pushbutton on?
Sign up to join this communityAs you know, there are two push buttons (MASTER SW and START) related to the APU in the Airbus A320 family.
Are there cases that the APU MASTER SW is used but not the Start PB?
Yes: diagnosis, emergency, and maintenance.
Diagnosis
Turning on the APU master switch without pressing the start button triggers the following actions:
If something is not working, you can try to see in the ECAM page what is happening without actually starting the APU.
Emergency procedure
The procedure does not require to actually start the APU.
Maintenance
Many maintenance procedures require to power-up the APU but not start the APU. One case is also in the FCOM:
