What are these blue lines around the runway at the airport chart that I marked with red lines? They are not waterways or taxiways so what are they?
1$\begingroup$ what airport is this? $\endgroup$– RTOOct 7, 2022 at 14:55
$\begingroup$ Adana International Airport and Yenisehir Airport from Turkey. I've seen these blue lines several times on different charts. LTAF and LTBR btw. $\endgroup$– pilot162Oct 7, 2022 at 15:02
1$\begingroup$ And this is why you have to look out the windows when flying IFR. A glance a reality can tell you what charts & instruments won't. $\endgroup$– FreeManOct 7, 2022 at 16:25
1 Answer
They are in fact waterways: irrigation ditches or channels. The Jeppesen airport chart legend lists them as
32 — Ditches in the vicinity of the airport are depicted.
For example, looking at a Google Maps view of LTBR, the blue line charted west of the runways clearly refers to the Kurutma Kanali/Marmaracık Gölü Kurutma Kanali. The blue lines between the runways are not shown on the Google Maps terrain/relief view, but switching to the aerial imagery view reveals a drainage ditch on either side of Runway 07L. In fact there appears to be another one which Jeppesen does not depict on the south side of Runway 07R.
$\begingroup$ Thank you so much for your answer. Actually, the reason why I asked the question was the blue line between the runways, because there was nothing like a waterway between the runways while flying at that airport. But as a result, as you said, it becomes clearer when you check it from Google maps. $\endgroup$– pilot162Oct 7, 2022 at 18:00
