May I know if there are any turn and bank indicators on the pilots instrument panel and where is it located at?
1$\begingroup$ Related: What was the flying instrument panel layout type behind the yoke onboard the Antonov 225? $\endgroup$– BianfableJul 13 at 10:39
As has been pointed out in other posts, the top right instrument, appears to be a VSI (white needle) with an overlaid bank indicator (gold dial) over a ball slip/skid indicator.
$\begingroup$ That's not a VSI, the scale is wrong and it doesn't have a negative indication for descent. I have a Cuban friend who trained in Russia, I will ask him what it is. $\endgroup$ Aug 7 at 0:53
1$\begingroup$ It goes 10-20-30 clockwise, and 10-20-30 counter-clockwise, as a VSI would. You posted the picture! ;) See also i.stack.imgur.com/liZTS.png $\endgroup$– MaxAug 7 at 1:50
$\begingroup$ Turns out you nailed it. Combo VSI with an appropriate range for the behemoth's performance, with turn and bank. My friend Guajirovich confirmed it. 🤣 $\endgroup$ Aug 7 at 1:54
$\begingroup$ And sadly, these questions and comments are all worded present tense. The An-225 had a turn and bank. :( $\endgroup$– MaxAug 7 at 2:58
$\begingroup$ Nah. Has. The second one is going to be finished. cnn.com/travel/article/antonov-an-225-kiev-ukraine/index.html $\endgroup$ 2 days ago
