25
At first I wasn't even sure if any airlines flew southern Pacific great circle route flights, but it looks like Qantas (QFA27) operates a flight between Sydney and Santiago, Chile.
For northern Pacific greate circle routes, you are flying near Canada/Alaska and then Russia for most of the flight, so you have some airports you could potentially divert to if an emergency arose. I've search online for more details about how this works for these flight, but haven't had much luck finding information.
Are there any point on the southern Pacific great circle route for flights to divert to? Or is there not really any backup plan if something goes wrong? Are there specific requirements that must be met for an aircraft to fly this route?
    $\begingroup$ If you only have 2 engines, you play by the ETOPS rules (Engines Turn Or People Swim) and there are specific rules about distances to alternates at any given point on your route. If you have 4 engines, you have more leeway on alternates. I don't have the specifics to give you an answer, but hopefully someone else can provide that. $\endgroup$
    – casey
    Jan 12, 2014 at 5:03
    $\begingroup$ @casey The new(er) ETOPS rules actually apply to all airplanes, not just two engine airplanes like in the past. $\endgroup$
    – Lnafziger
    Jan 26, 2014 at 5:47
    $\begingroup$ I've actually flown this route. It's not a good feeling to know that you are 4+ hours away from a safe touchdown on land in the event of a problem. $\endgroup$
    – user2605
    Jun 14, 2014 at 6:56
    $\begingroup$ amazing QA here ! $\endgroup$
    – Fattie
    May 17, 2017 at 23:40
31
This particular flight was a Boeing 747 flying from YSSY (Sidney) to SCEL (Santiago). Because a 747 has more than two engines, they don't have specific time limits on how far from land that they can fly like two engine airplanes do.
That being said, they do have to carry enough fuel to make it to a suitable airport in the event that the airplane depressurizes or it has an engine failure at any point along their route.1. This doesn't mean that they have to make it all of the way to their destination in the event of a problem though. They use en-route diversion airports and have predefined points on their flight plan which tell them where to divert to at any given point during the flight.
You will notice on this flight (see the images below) that their planned route is considerably further North than the shorter great circle route. This is probably so that they can use NTAA (Tahiti) as a diversion airport if they have a problem. The route is also optimized for the current winds at the cruising altitude, so it may be more fuel efficient to go out of the way in order to have more favorable winds.
In this case, without seeing their actual dispatch paperwork we can't know for sure whether or not they could have even flown the great circle route with the amount of fuel that the airplane can hold, but we'll just assume that they are using NTAA as an ETOPS airport for the purposes of this discussion. That being said, we will use the following airports as our ETOPS diversion airports: NZCH, NTAA, and SCEL. In this case, their diversion plan in the event of an emergency would probably be something like this:
  • From takeoff (YSSY) until a point a little less than half way to NZCH (New Zealand)2 they would divert back to their point of departure2
  • From a little less than half way to NZCH until a point around 46W52 they would divert to NZCH.
  • Between the points that would be around 46W52 and 47W25 they would divert to NTAA.
  • After 47W25 they would continue on to their destination (SCEL) because it would be faster than turning around and going back to any of the other airports.
Each of the points takes wind into consideration, and as they pass each one they will always know which airport that they can reach in the least amount of time. The most important thing is that they always have enough fuel to make it somewhere safe in the event of an emergency.
QFA27 Filed Route Filed Route
Great Circle Route Great Circle Route
1 They also have to carry enough fuel to fly to their alternate airport and additional contingency fuel. One thing to keep in mind is that a jet burns considerably more fuel at low altitudes than they do at their optimum altitude, so they have to carry a lot of extra fuel to meet this (and other) requirement.
2 If they turned around at the exact halfway point, it would take them longer to return than to continue because of the East winds.
Regulations
For those of you interested in the actual fuel requirements for a flight like this, the US regulations are listed in 14 CFR 121. I'll use these as an example (other countries will be very similar, but I know these.)
You will notice that almost every line of the regulations listed here will require extra fuel to be on board the airplane. (Look for the ✈ symbol next to each one that I have added.) Fortunately, it isn't quite as bad as it looks though, because some of the fuel that is pumped into the airplane can be used for more than one purpose. For instance, a portion of the fuel may be used to divert to an ETOPS airport and used to fly to your destination, because they will only be doing one or the other. The pertinent regulations are summarized here:
§121.645 - Fuel supply: Turbine-engine powered airplanes...
(b) For any certificate holder conducting flag or supplemental operations outside the 48 contiguous United States and the District of Columbia, unless authorized by the Administrator in the operations specifications, no person may release for flight or takeoff a turbine-engine powered airplane (other than a turbo-propeller powered airplane) unless, considering wind and other weather conditions expected, it has enough fuel—
✈ (1) To fly to and land at the airport to which it is released;
✈ (2) After that, to fly for a period of 10 percent of the total time required to fly from the airport of departure to, and land at, the airport to which it was released;
✈ (3) After that, to fly to and land at the most distant alternate airport specified in the flight release, if an alternate is required; and
✈ (4) After that, to fly for 30 minutes at holding speed at 1,500 feet above the alternate airport (or the destination airport if no alternate is required) under standard temperature conditions.
§121.646 - En-route fuel supply: flag and supplemental operations.
(a) No person may dispatch or release for flight a turbine-engine powered airplane with more than two engines for a flight more than 90 minutes (with all engines operating at cruise power) from an Adequate Airport unless the following fuel supply requirements are met:
(1) The airplane has enough fuel to meet the requirements of §121.645(b);
✈ (2) The airplane has enough fuel to fly to the Adequate Airport—
✈ (i) Assuming a rapid decompression at the most critical point;
✈ (ii) Assuming a descent to a safe altitude in compliance with the oxygen supply requirements of §121.333; and
✈ (iii) Considering expected wind and other weather conditions.
✈ (3) The airplane has enough fuel to hold for 15 minutes at 1500 feet above field elevation and conduct a normal approach and landing.
(b) No person may dispatch or release for flight an ETOPS flight unless, considering wind and other weather conditions expected, it has the fuel otherwise required by this part and enough fuel to satisfy each of the following requirements:
✈ (1) Fuel to fly to an ETOPS Alternate Airport.
✈ (i) Fuel to account for rapid decompression and engine failure. The airplane must carry the greater of the following amounts of fuel:
✈ (A) Fuel sufficient to fly to an ETOPS Alternate Airport assuming a rapid decompression at the most critical point followed by descent to a safe altitude in compliance with the oxygen supply requirements of §121.333 of this chapter;
✈ (B) Fuel sufficient to fly to an ETOPS Alternate Airport (at the one-engine-inoperative cruise speed) assuming a rapid decompression and a simultaneous engine failure at the most critical point followed by descent to a safe altitude in compliance with the oxygen requirements of §121.333 of this chapter; or
✈ (C) Fuel sufficient to fly to an ETOPS Alternate Airport (at the one engine inoperative cruise speed) assuming an engine failure at the most critical point followed by descent to the one engine inoperative cruise altitude.
✈ (ii) Fuel to account for errors in wind forecasting. In calculating the amount of fuel required by paragraph (b)(1)(i) of this section, the certificate holder must increase the actual forecast wind speed by 5% (resulting in an increase in headwind or a decrease in tailwind) to account for any potential errors in wind forecasting. If a certificate holder is not using the actual forecast wind based on a wind model accepted by the FAA, the airplane must carry additional fuel equal to 5% of the fuel required for paragraph (b)(1)(i) of this section, as reserve fuel to allow for errors in wind data.
✈ (iii) Fuel to account for icing. In calculating the amount of fuel required by paragraph (b)(1)(i) of this section (after completing the wind calculation in paragraph (b)(1)(ii) of this section), the certificate holder must ensure that the airplane carries the greater of the following amounts of fuel in anticipation of possible icing during the diversion:
✈ (A) Fuel that would be burned as a result of airframe icing during 10 percent of the time icing is forecast (including the fuel used by engine and wing anti-ice during this period).
✈ (B) Fuel that would be used for engine anti-ice, and if appropriate wing anti-ice, for the entire time during which icing is forecast.
✈ (iv) Fuel to account for engine deterioration. In calculating the amount of fuel required by paragraph (b)(1)(i) of this section (after completing the wind calculation in paragraph (b)(1)(ii) of this section), the airplane also carries fuel equal to 5% of the fuel specified above, to account for deterioration in cruise fuel burn performance unless the certificate holder has a program to monitor airplane in-service deterioration to cruise fuel burn performance.
✈ (2) Fuel to account for holding, approach, and landing. In addition to the fuel required by paragraph (b)(1) of this section, the airplane must carry fuel sufficient to hold at 1500 feet above field elevation for 15 minutes upon reaching an ETOPS Alternate Airport and then conduct an instrument approach and land.
✈ (3) Fuel to account for APU use. If an APU is a required power source, the certificate holder must account for its fuel consumption during the appropriate phases of flight.
§121.647 - Factors for computing fuel required.
Each person computing fuel required for the purposes of this subpart shall consider the following:
✈ (a) Wind and other weather conditions forecast.
✈ (b) Anticipated traffic delays.
✈ (c) One instrument approach and possible missed approach at destination.
✈ (d) Any other conditions that may delay landing of the aircraft.
For the purposes of this section, required fuel is in addition to unusable fuel.
  • 7
    $\begingroup$ As it happens I am living in the southern part of New Zealand (Te Anau) where there is virtually no airliner traffic overhead - except for QF27. On a clear day, they will usually be making contrails so quite evident. So sorry to digress from your detailed post but the flightpath is quite a bit more south than the image you have posted. I checked on flightradar24 and the track is in fact even more south than me (I'm about 45.5S) Plus they will likely be adhering to Australian CASA regs flying VH registered aircraft but the equivalent FARs are probably easier to find. But great post. $\endgroup$
    – timbo
    May 4, 2015 at 23:52
    $\begingroup$ @timbo Great, thanks for the info! As I mentioned, the winds play a large role in route selection, so this particular flight may not be the optimum flight all of the time. Welcome to the site! $\endgroup$
    – Lnafziger
    May 7, 2015 at 3:11
  • $\begingroup$ Quibble - from about halfway between 46W52 and 47W25 to about halfway between 47W25 and SCEL, SCIP would be a better option than either NTAA or SCEL, what with being (sometimes considerably) closer and all. $\endgroup$
    – Vikki
    Jun 10, 2018 at 17:10
    $\begingroup$ @Sean That might be a good diversion airport to use, but I noticed on their wiki that they severely restrict the number of airplanes that can use it (only one airplane at a time can be in the area that can divert to it). I'd have to run the flight plan again to see if it even helped, but good find! $\endgroup$
    – Lnafziger
    Jun 12, 2018 at 17:38
  • $\begingroup$ @Lnafziger: True, but, since that flight is passing through said area of airspace anyways, it doesn't matter whether it actually intends to land at SCIP or not - while it's within SCIP's sphere of influence, no other aircraft can be in that airspace, and vice versa (what if they had an emergency necessitating an immediate landing at the nearest airport, which happened to be SCIP, and the runway was blocked by another aircraft?). $\endgroup$
    – Vikki
    May 5, 2019 at 3:18
On the great circle route from Sydney to Santiago, from southern New Zealand (past Invercargill, maybe) to southern Chile, there is a stretch of about 4,000 nm with no landing sites.
There are specific requirements for air carriers for "extended overwater operations." These take into account the aircraft range after engine failure, distance to diversion airports, emergency equipment and training, etc. There is definitely a backup plan in place for every overwater airline flight.
A twin engine jet airliner will have an ETOPS (Extended range Twin Operations) rating that is the distance it able to reliably fly, fully loaded, on one engine. Many Boeing 777s have an ETOPS rating of 330 minutes, for example, which means they must fly on a route that keeps them within 5.5 hours of an airport at single engine speed.
Airliners conducting extended overwater operations must be ditching certified, which involves aircraft design, emergency equipment, and crew training for emergency water landings.
