As the title says for private airports and planes that fly in and out of them is there a frequency that they use and if so where can it be found?
1$\begingroup$ There are a few (pvt) Private-Use airports that actually publish a frequency to use in the data next to the airport symbol on a sectional chart. $\endgroup$– 757togaJun 30 at 0:27
1 Answer
Referencing AIM: Services Available to Pilots/Summary of Recommended Communication Procedures (Link).
No Tower, FSS, or UNICOM -Self‐announce on MULTICOM frequency 122.9
However - as you may expect, the short of it is - it's private - so nobody will be listening most likely. I'm only listing the AIM reference as the most authoritative source - which even then - likely doesn't even fully cover this.
I'd have to imagine that some of these are owned by individuals living on a ranch like setting in a remote area, and assume that they are going to be the only individuals using the runway (unless an emergency happens). Even if an emergency happens, the individual is unlikely going to be listening to this radio. In this "individually owned" scenario, it's also unlikely any pattern work is going on.
In other situations, these may be owned by a flight school or a private group. I'd have to imagine in this case - they select one of the common CTAF frequencies also published in this table.
General Note: The owners of these opt to chart them for your safety in case of an emergency, and not much else. Some may be more generous and allow you to reach out to them with advance planning in certain limited circumstances. The bottom line is to realize that these fields are private for a reason.
1$\begingroup$ There are a few (pvt) Private-Use airports that actually publish a frequency to use in the data next to the airport symbol on a sectional chart. $\endgroup$– 757togaJun 30 at 0:26
