When I was watching Top Gun Maverick, the EWAC called the 2 incoming SU-57s “bandits”, but when Maverick says it he says “bogies incoming“. (Correct me if that isn’t what they said).
So why don’t they just call them "bandits" and not "bogies".
According to the Multiservice Tactical Brevity Codes
a Bandit is
An aircraft identified as enemy, in accordance with theater ID criteria. The term does not necessarily imply direction or authority to engage.
and a Bogey is
A radar or visual air contact whose identity is unknown.
The RAF had a much smaller set of codes but the meaning is fairly consistant with the American/NATO codes above
Bandit – identified enemy aircraft.
Bogey – unidentified (possibly unfriendly) aircraft.
Traditionally, a 'bandit' is identified bad guy, whereas a 'bogey' is unidentified - could be bad guy, could be one of ours.
