I was looking and saw that the British developed a missile called the ASRAAM, which was not adopted by the United States. Why? Also, how do the AIM-9X and ASRAAM compare? In which situation would one be better than the other?
  • $\begingroup$ What has your research shown? It is sort of a new and improved AIM-9. $\endgroup$
    – WPNSGuy
    Jun 26, 2022 at 23:09
  • $\begingroup$ So far, it has said the ASRAAM is better, but the answers all seem like random British people who want to one-up America in as many ways as they can. About the actual capability, I can't decide, as the AIM-9X can pull harder g turns, both have a Lock on after launch capability, and the ASRAAM is harder to jam. I also figured the AIM-9X be better in some ways since the USAF chose the AIM-9X. If the ASRAAM were better in all ways, they would have modified their planes to carry the ASRAAM. $\endgroup$
    – JustACoder
    Jun 27, 2022 at 0:05
  • $\begingroup$ The reasons are not always technical: "While ASRAAM was entering production, momentum behind US-led industrial and political lobbying grew significantly and, combined with the strengthening European economy, forced the US government to conclude testing in June 1996 and move away from the ASRAAM program." (from en.wikipedia.org/wiki/Asraam) $\endgroup$ Jun 27, 2022 at 1:56
  • $\begingroup$ Performance of military weapons is off-topic here. $\endgroup$
    – Bianfable
    Jun 27, 2022 at 6:06
    $\begingroup$ I'm voting to close this as opinion based. Which is better is subjective. $\endgroup$
    – GdD
    Jun 27, 2022 at 9:29
Why was the ASRAAM not adopted by the USA? Officially the ASRAAM was evaluated in the context of tender. The entries were the AIM-9X Sidewinder and the ASRAAM. However it was rejected as a result of tests conducted during that evaluation (link). Therefore, simple as that, the missile was evaluated and found to be not satisfactory, or less satisfactory then its competition (the AIM-9X).
I could however not find a source citing if explicit reasons where given. However a lot of speculation emerged if this decision was based on factual reasons such that the ASRAAM could not be deployed on aircraft carriers, does have unsatisfactory turning performance shortly after firing or if the sidewinder simply had more value because exisiting motor sections could be reused (apparently 20.000 of these sections were still around and could be reused). Other reasons could include political considerations: Perhaps the USA did not want to buy "foreign" material. But again, that is speculative.
Which of the two missiles is better? This very much depends on requirements. Both missiles use the same Hughes IR Seeker (a focal plane imaging array seeker). Both have a very similar combat deployment scenario: That of a short-range engagment. The key differences are:
  • The ASRAAM has higher range due to less aerodynamic drag and a bigger motor
  • The AIM-9X is better at initial turning rate which offers an advantage shortly after the missile leaves the launch rail.
  • The AIM-9X has a smaller diameter (127mm vs 166mm) therefore less space for warhead, motor etc.
  • The warhead of the AIM-9X is a bit smaller, therefore less lethal
  • There are differences in how both missiles compute their guidance solution in response to flares, resulting in differences in performance in this respect. The exact differences are classified
However interesting to note is that both missiles acquired some upgrade in order to counter these points: The AIM-9x was upgraded in the Block III variant to improve its range (and also to gain a lock-after-launch capability), while it was apparently important for BAE to issue an upgrade for the ASRAAM which enables it to hit targets behind the aircraft (also coupled with lock-after-launch capability).
