For reference this is the NDB ILS DME RWY 24 approach at EGPH. When arriving from the south/southwest, I am sure you would be vectored in but i am interested as to how this would be done without vectors. Assuming you are not coming from TLA, this would mean you cannot use the DME arc so your inital approach fix would be EDN, requiring a course reversal on the racetrack.
A few points:
- What is the smaller racetrack inside the larger one?
- I am assuming this would require a parallel entry? If so, how long would you travel along the inbound section before turning back around?
- Could you descend and intercept the glideslope after completing the racetrack/hold entry or would you have to do the entry, get back to EDN, then go back around the main racetrack to the top of the glideslope?
