Aircraft operating in icy conditions are equipped with de-icing equipment to remove ice from specific parts of the aircraft (wing, sensors,...) in flight.
When there is snow or icy conditions while the aircraft is still on ground, it is de-iced with ground equipment (de-ice fluid, towel,...).
Is the aircraft's own de-icing equipment also used?
Is this equipment enough to de-ice an aircraft before take-off (lets say if this is a sunny day and the temperature is just below 0°C)?
  • $\begingroup$ Why would you want to use the plane's very limited resources to do something that the airport is better equipped to do for you? $\endgroup$ Commented Oct 28, 2014 at 9:53
  • $\begingroup$ @DavidRicherby To keep generality, I never specify the aircraft type neither the airport. It may be a military transport aircraft transporting stuff to (re)build the airport it is standing on. It may also be a A380 standing at LAX, a DHC-6 at Lukla, ... And what I want is knowledge about how it is done, possibly with references. $\endgroup$
    – Manu H
    Commented Oct 28, 2014 at 12:43
    $\begingroup$ @DavidRicherby Because the airport you're at isn't equipped to do it. So, start up the airplane, turn the prop heat on, pop the boots a few times, then shut down and get busy with a whisk broom, rags, and whatever else will work. $\endgroup$
    – Terry
    Commented Oct 28, 2014 at 17:41
12
Usually, no.
There are two main methods used to deice an airplane in the air. One is letting warm air that is bleed from the jet engine to heat the wing leading edge. The other is to have have rubber air bladders (called deice boots) on the leading edge of the wing and tail surfaces that are pumped up and the ice falls off. Both of those methods are only useful to deice the leading edge of the wing and tail surfaces which is pretty much the only dangerous place where an airplane can gather ice while it is flying.
Airplanes on the ground are a different story. Ice can be built up pretty much anywhere as there is no airflow to prevent it. Excessive ice on control surfaces can make them behave "unevenly" or in extreme cases even unresponsive. Bigger chunks of ice breaking off the fuselage can get ingested by the engine and cause problems. It is therefore important that the airplane takes off ice-free. In fact, as little as frost on the surface of the wings can cause a significant loss of lift and can even cause a plane to crash.
  • $\begingroup$ You begin your answer with "usually". Does it mean there are cases where you use both aircraft and ground de-ice capabilities at the same time? $\endgroup$
    – Manu H
    Commented Oct 28, 2014 at 12:45
  • $\begingroup$ @ManuH It is not improbable that small GA airplanes that are fitted with technologies like the TKS Ice Protection system or passive anti-ice materials are theoretically able to adequately de-ice themselves on the ground. $\endgroup$ Commented Oct 28, 2014 at 13:08
  • $\begingroup$ @RRR Most of the TKS systems I'm familiar with for light GA ("weeping wing" systems and prop slingers, like CAV Aerospace's system) require some forward movement of the aircraft to keep the wings clean (the fluid sheets back in the slipstream). Prop slingers would probably work at ground idle, but I'm not sure how effective they'd be at getting deice fluid to the tips... $\endgroup$
    – voretaq7
    Commented Oct 28, 2014 at 17:13
    $\begingroup$ @RRR I agree with your statement that the leading edge of the wing is pretty much the only dangerous place where an airplane can gather ice while it is flying if the aircraft is a jet. However, propeller icing can also be dangerous. Antennae icing, while not dangerous, can also be a significant nuisance, even to the extent of an antennae tearing off (happened to me only once). Also, again in the nuisance category, ice on 747 windshield wipers can cause them to vibrate and set up a loud buzz in the cockpit that is very annoying. $\endgroup$
    – Terry
    Commented Oct 28, 2014 at 17:32
Yes, anti-ice equipment is sometimes used on the ground, but is usually not sufficient to clear the plane of ice.
Airplane systems are generally referred to as anti-ice, because they are designed to prevent ice from forming or accumulating. Airport equipment is referred to as de-ice, because it is designed to remove ice as well as preventing it from forming (to some degree). So, as others have said, the real de-icing equipment available on the ground is much more effective than what is on the plane.
Anti-ice systems are generally designed to protect key areas of the airplane where ice is most likely to form in flight; leading edges of the wings, engine cowls/props, and pitot-static or other sensors. However, on the ground, it will accumulate on other exposed surfaces like wings/stabilizers/fuselage. This is why the de-ice measures are needed, to clear off those surfaces as well, because ice on the wings is bad.
However, anti-ice equipment may be used on the ground as well when needed. Air Florida Flight 90 crashed shortly after takeoff in icing conditions, and a contributing factor was ice accumulating on engine sensors which prevented the engines from providing full thrust. So when icing is expected, the anti-ice systems will certainly be used on the ground to provide added protecting to the most critical surfaces, in addition to the protection from de-icing procedures. Failing to have the wing and control surfaces properly de-iced also contributed to that accident.
Also, see this related question: Why turn off pitot tube heating?
  • $\begingroup$ Good points. We used engine A/ice on the ground in visible moisture with SAT <= 10C to prevent similar issues to that air florida crash. $\endgroup$
    – casey
    Commented Oct 28, 2014 at 21:26
