Does anyone know what the thrust-to-weight ratio is for the Airbus A330-900neo?
I'm getting different numbers when I try to calculate this for myself.
Sign up to join this communityDoes anyone know what the thrust-to-weight ratio is for the Airbus A330-900neo?
The thrust-to-weight ratio is not a single number because both thrust and weight vary throughout a flight:
The thrust-to-weight ratio varies continually during a flight. Thrust varies with throttle setting, airspeed, altitude and air temperature. Weight varies with fuel burn and payload changes. For aircraft, the quoted thrust-to-weight ratio is often the maximum static thrust at sea level divided by the maximum takeoff weight.
(Wikipedia: Thrust-to-weight ratio)
For standard sea level conditions with maximum takeoff thrust and at maximum takeoff weight, we would get the following numbers (source) for the A330-900:
Thrust / Engine | Total Thrust | Mass | Weight | Thrust-to-weight ratio |
324 kN | 648 kN | 251 t | 2462 kN | 0.263 |
