- Weight & Balance:
SERA Annex VII (Part-NCO)
Non-commercial operations with other than complex-motor-powered aircraft
Subpart C: AIRCRAFT PERFORMANCE AND OPERATING LIMITATIONS
NCO.POL.100 Operating limitations – all aircraft
During any phase of operation, the loading, the mass and, the centre of gravity (CG) position of the aircraft shall comply with any limitation specified in the AFM or equivalent document.
and
Subpart A: GENERAL REQUIREMENTS
NCO.GEN.135 Documents, manuals and information to be carried
The following documents, manuals and information shall be carried
on each flight as originals or copies unless otherwise specified:
(1) the AFM, or equivalent document(s);
(2) the original certificate of registration;
(3) the original certificate of airworthiness (CofA);
(4) the noise certificate, if applicable;
(5) the list of specific approvals, if applicable;
(6) the aircraft radio licence, if applicable;
(7) the third party liability insurance certificate(s);
(8) the journey log, or equivalent, for the aircraft;
(9) details of the filed ATS flight plan, if applicable;
(10) current and suitable aeronautical charts for the route area of
the proposed flight and all routes along which it is reasonable to
expect that the flight may be diverted;
(11) procedures and visual signals information for use by intercepting
and intercepted aircraft;
(12) the MEL or CDL, if applicable; and
(13) any other documentation that may be pertinent to the flight or is
required by the States concerned with the flight.
So, per SERA, the weight & balance sheet does not need to be carried on-board. Pre-flight weight & balance calculations must show that the airplane remains within loading limits from takeoff weight to landing weight.
- Paper & Digital Versions:
Edit:
GM1 NCO.GEN.135 Documents, manuals and information to be carried now reads:
The documents, manuals and information may be available in a form other than on printed paper. An electronic storage medium is acceptable if accessibility, usability and reliability can be assured.
