What is the best way to mathematically calculate values of lift and drag forces, in different phases of flight: takeoff, climb, cruise, descent, and approach?
Edit: I have the idea of calculating the lift force by using the information of speed and angle of attack (for the coefficient of lift value) in different flight phases from the pilot's "flight manual" (if it is obtainable there), in standard ISA conditions L=CL*(r+v⌃2/2)x wing area. For drag, I would use same inf. and the total drag coefficient is equal to the drag coefficient at zero lift, plus the induced drag coefficient Cd = Cd0 + Cl^2 / ( pi * Ar * e), where The efficiency factor (e) is equal to 1.0 for an elliptic distribution and is some value less than 1.0 for any other lift distribution. –
  • $\begingroup$ Welcome to the site Tom. I see you haven't taken the tour yet, so please do. Also please press Edit to add the requested information to the question body, highlighting for example why you think that method doesn't work. $\endgroup$
    – user14897
    May 15, 2022 at 11:21
So lift and drag are properties directly proportional to the angle of attack (AoA) of the aircraft. The equation for lift and drag of an airfoil would be:
L=N*cos(phi)-Asin(phi)
D=N*sin(phi)+Acos(phi)
N and A represent force in the normal direction and in the axial direction respectively.
And N is dependent on the pressure on the airfoil, while A depends on the shear stress on the airfoil.
So if given the airfoil parameters, AoA, pressure, and shear stress, you can calculate the lift and drag. Free Body Diagram of an airfoil
Moreover, if you are given the lift and drag coefficient, you would simply use the equation
C_{L}=L/(q_inf*S)
C_{D}=D/(q_inf*S)
and q_inf here denotes the dynamic air pressure far away. The equation for q_inf is q_inf=1/2rho_infV_inf^2. And as you may have guessed, rho_inf is the density far away and V_inf is the free stream velocity far away. (This equation is very similar to 1/2mv^2)
And S in this case is the surface area of your airfoil, or more generally speaking, the size of your object.
I hope this helped a little :)
  • $\begingroup$ You probably mean alpha not phi $\endgroup$
    – Jim
    May 15, 2022 at 17:55
