I guess we should start with saying that over many orders of magnitude of Reynolds number, it would be likely that the coefficient of lift would in fact change. This is why insects, birds, and aircraft use different aerodynamics, depending on their size. However, if we are assuming the presupposition that it doesn't change is true, we can limit this to be for an aircraft in a certain range of viscosities.
Basically, the relative difference in the flow speed, how much faster the upper flow is relative to the lower flow (equivalent to the how much higher the lower pressure is relative to the upper pressure), is independent of the freestream velocity, and is dictated by the properties of the fluid and the geometry of the aerofoil. Even that is not necessary, it turns out that if an aerofoil is thin enough, then even the geometry does not affect the relative velocities or pressures.
So, while in a faster flow the total lift force may be greater, the coefficient of lift is only determined by the angle of attack, in a fluid with viscosity. That is, for a given freestream velocity (the TAS of an aircraft) the relative change in static and dynamic pressure is independent of the initial velocity and is only a function of the angle of attack.
Just to pre-empt any comments, circulation is a difference in flow speed above an aerofoil relative to below and is used to calculate coefficients of lift. It may be more common to talk about this as circulation, but when added to the freestream velocity component from potential flow, the net result is flow going much faster over the upper surface and much slower under the lower surface. And very importantly, when we do experiments in wind tunnels, we measure pressure using manometers so there is a lower pressure above relative to below. These two phenomena are in fact interchangeable, hence the reason we integrate the pressure coefficient along the upper and lower surfaces which is equivalent to the closed contour integral of circulation.
