I was wondering if there is a name for this particular structure on Su-27 and F-22 and if they serve any function?
1 Answer
On the SU-27 that is where the rear fire control radar is housed. On the F-22 it is the runaway arrestor hook housing.
3$\begingroup$ runaway arrestor ? Like some kind of Blade Runner ? $\endgroup$– JeffreyApr 26, 2022 at 0:39
1$\begingroup$ @Jeffrey Ever seen the ramps on highways for runaway trucks whose brakes have failed? Similar concept. On a military runway you install something like this safran-group.com/products-services/… so aircraft whose brakes have failed and don't have any other means of slowing down other than an arrestor hook can safely come to a stop. And yes, something like a blade runner. :) $\endgroup$ Apr 26, 2022 at 17:44
$\begingroup$ @JuanJimenez, do you have a reference for the Su-27 rear fire control radar? I'm curious about that. Thanks. $\endgroup$– TylerSep 14, 2022 at 21:36
$\begingroup$ @Tyler I did a little more research and I think it may be the radar illumination warning system component of the fire control system, and I am not even sure if that wording is correct. There is an SPO-15 Beryoza system for that with an indicator in the cockpit (on the bottom right hand side of the instrument panel), and I think I found that the rear boom also contains the chaff dispensing system. The info I found suggests it is also used in the Mig-29 and Chinese J-11. I am not really an expert on this, I just digged up the best info I could find. $\endgroup$ Sep 15, 2022 at 22:44
