Is fuel efficiency the only reason why hypersonic missiles don't use rocket engines?
And why are rocket engine missiles relatively slow compared to scramjet missiles? In theory rocket engines can produce more than enough thrust for 24Mach speeds?
Sign up to join this communityIs fuel efficiency the only reason why hypersonic missiles don't use rocket engines?
Hypersonic missiles fly through the atmosphere and remain manoeuvrable until impact, making it much harder to defend from them. And since they're flying through the atmosphere they use atmospheric air for combustion.
The main advantages of rocket engines:
The main disadvantage of rocket engines:
Hypersonic missiles only need to carry fuel and payload, which they oxidise with air which is also used as a reaction mass. Without having to eject bits of its construction with perfectly functioning engines, and using wings to create lift and flight control surfaces to control flight path just like an aeroplane. But launching them is an issue: flying faster than Mach 5 they are propelled by scramjets, which cannot be operated from a standstill like rockets can. So they need to be launched by either a rocket or from an aeroplane, preferably a really fast one.
Is fuel efficiency the only reason why hypersonic missile don't use rocket engines?
It's the main reason, yes. While exclusively flying trough the atmosphere it makes no sense to not use the unlimited amount of reaction mass of atmospheric air for combustion.
Whether rocket propelled or scramjet propelled, when flying through the atmosphere the missile heats up and therefore there are limits on the maximum attainable velocity. A rocket propelled missile can definitely reach the same speed as a hypersonic missile, there is nothing slow about them.
The two pictures linked to a from a site that explains the basics of missile threats, a worthwhile read.
Mach 24 in the atmosphere? Not for long. Ask any meteor.
Developing airbreathing technology may improve fuel efficiency, but oops, the drag of the intake and heating from compression may cancel any advantages airbreathing technology gives. In short, try as they may, hypersonic jets do not seem to be advancing beyond the research stage.
The Kh-47M2 Kinzhal air launched solid fueled rocket is a very practical solution, but one that could be answered with one of these, also carried by an aircraft, if needed.
Speed vs maneuverability rages on.
