Can any one please identify this monoplane with a huge curved exhaust.
$\begingroup$ I still think OP was mis-identifying the curved roll-over structure as being a gigantic exhaust pipe, with the black material of the cockpit "coaming" (rim) being mistaken for the open end of the pipe! $\endgroup$– quiet flyerMar 29 at 0:00
$\begingroup$ Many thanks to you all for taking the time to answer ther question - much appreciated. $\endgroup$– TigerMar 29 at 14:31
1 Answer
I believe this is a Junkers T29, or something similar. This photo from behind shows that the plane has both a rollbar over the cockpit as well as a separate exhaust pipe that sticks up prominently from the engine. Image Source
1$\begingroup$ Wikipedia says the curved thing is a “longitudinal arch over their heads to protect them like a roll bar” en.wikipedia.org/wiki/Junkers_T_29 $\endgroup$ Mar 28 at 16:39
4$\begingroup$ Only two were built. More photos of the Junkers T29 here: www-airwar-ru.translate.goog/enc/other1/… $\endgroup$ Mar 28 at 16:44
2$\begingroup$ The T29 was also a test platform for the doppelflugel, which is that funky double-wing control surface. Nice catch. $\endgroup$ Mar 28 at 19:08
$\begingroup$ @MikeSowsun Nice find. This photo appears to be the same as the one in the OP, albeit in better quality $\endgroup$– BergiMar 29 at 1:56
1$\begingroup$ @DarrelHoffman: It's not hard to imagine an airplane of this configuration nosing over on landing and ending up on its back, especially when used in a training role. $\endgroup$ Mar 29 at 13:43
