11
What propulsion method is used for small short range handheld missile systems? Liquid fuel rocket engines are the gold standard but I suspect require too many components for the size requirements.
Is it solid fuel rockets or is there some other method? Looking at the outside it doesn't look like they have a turbine or air intake.
    $\begingroup$ In order not to burn operator the missile must accelerate to (or close to) cruise speed before the tail leaves the tube. Only a solid booster can burn this fast. Had you picked another propulsion, then the missile must a two-stage. $\endgroup$ Mar 24, 2022 at 16:50
39
Missiles like a LAWS or Stinger use solid rocket motors.
Despite liquid fuel being preferred for space launchers, for a MANPADS type missile the combination of storability, inertness in transport, low toxicity, and near-zero setup time, along with the very limited performance requirement (compared to longer range missiles) make solid propellant virtually universal.
Don't forget, these missiles are closer, size, weight and performance wise, to a High Power model rocket than to even an SRBM -- and much larger missiles (like the long-running Sidewinder) use solid propellant for the same reasons. Unlike models, however, these missiles are steerable -- various ones either have seeker heads (like the Sidewinder, too large for shoulder launching, but still solid propellant and small by missile standards), or are wire or radio guided. Steering is accomplished either aerodynamically, with movable fins (like the Sidewinder), or by thrust vectoring with either a gimballed nozzle or jet vanes (the last is technology that goes back to the 1940s on the A-4 and Wasserfall).
While solid propellant rockets aren't practical to throttle, missiles typically don't care beyond a timed thrust profile to facilitate operator safety -- typically "big push to exit launcher, short idle to provide standoff from the operator, then cruise thrust". They're then expected to remain under near constant thrust until warhead detonation (or self destruction on a miss).
Some, of course, like an RPG, or WWII bazooka, aren't steered at all; rather, they're aimed like a gun.
Liquid fuels that can be stored and launched on short notice are very toxic (hydrazine derivatives and nitrogen oxides, either of which will kill you quickly). Those that are less toxic require much more infrastructure, as they almost universally use liquid oxygen (which has to be kept a lot colder than dry ice), and that has to be filled immediately before launch -- and has its own hazards.
    $\begingroup$ Thanks, that makes sense. One thing though, my understanding is that solid rocket engines do not allow for thrust control, it seems like this would be a problem. $\endgroup$ Mar 23, 2022 at 18:02
    $\begingroup$ Throttling, no, vectoring, yes, via gimbaled nozzle or jet vanes. I'll edit in. $\endgroup$
    – Zeiss Ikon
    Mar 23, 2022 at 18:10
    $\begingroup$ @JohnK Yep, 3rd paragraph, "A-4 and Wasserfall" -- V-2 was the Allied propaganda name for the A-4. Redstone used the same method as A-4 -- jet vanes coupled with movable fin sections. $\endgroup$
    – Zeiss Ikon
    Mar 23, 2022 at 18:53
    $\begingroup$ @FourierFlux Partially true. While solid rocket motors can't be throttled in flight, the thrust profile over time can be controlled by changing how the propellant is arranged inside the combustion chamber during production. $\endgroup$ Mar 24, 2022 at 8:26
    $\begingroup$ That’s a great book for sure, @PeterKämpf. And on the subject of thrust control, missiles at this range don’t need much thrust level control besides “go” once they’re out of the launcher and a safe distance away, and the low altitude gives multiple options for steering. $\endgroup$ Mar 24, 2022 at 10:43
15
Most shoulder-fired missiles, whether anti-tank or anti-aircraft, are actually two-stage rockets. The first stage is a very fast-burning motor, designed to burn out before the missile exits the launch tube. There is then a short delay, designed to get the missile some distance away from the launcher before the much larger main stage motor fires. The back-blast from a main motor can be 15-20 feet, definitely not healthy for the operator. High speed video of a launch will show the missile popping out and maybe even dropping a foot or two vertically before the main stage fires.
