In the recent Netflix documentary, a claim is made that once MCAS activated, after several activations, the pilots physically could not trim the aircraft due to the speed and pitch.
Is this true? I didn't think the trim wheel required pounds of force like the yoke does.
    $\begingroup$ From this answer: "Excessive airloads on the stabilizer may require effort by both pilots to correct the mis-trim. In extreme cases it may be necessary to aerodynamically relieve the airloads to allow manual trimming." $\endgroup$
    – Bianfable
    Mar 8, 2022 at 10:48
    $\begingroup$ Are you happy for this to be closed as a duplicate of the question linked above? The question is clearly different but the answer looks to answer your question too. Or, did you want some more information not supplied by that answer? If so, can you elaborate on what, specifically, you want to know that's not covered. $\endgroup$
    – Jamiec
    Mar 8, 2022 at 11:49
12
The problem was they could not manually trim the a/c without performing the Boeing "offload the jack" procedure developed for the 737, which requires altitude to perform because you are forced to let the airplane dive to do the offloading (in the case of a nose down runaway).
The basic problem is, if you are holding a large displacement of the elevator surface from neutral, it induces a large additional torque force, or pitching moment, within the horizontal tail system itself, much higher than with the elevator at neutral.
This torque force is absorbed by the trim screw jack and is relatively light when the elevator is at neutral, aligned with the chord line of the stab surface. However, at very large elevator displacement, the load on the screw jack, induced by the twisting force built up within the tail assembly by the elevator displacement, is more than can be overcome with the leverage available to the manual trim wheel system.
It's like you are jacking a car with one of those little scissors jacks they come with, and normally you can turn the screw fairly easily with just the normal weight of the car, but then an elephant climbs onto your car (the up elevator input), and the extra weight loads up the jack so much you can't turn it by hand any more.
The only way to turn the screw is the make the elephant get off the car, but if the elephant climbs off, the car will tip over, so you are kind of stuck.
The Boeing crew were holding elevator prevent the plane from nosing over, but this prevented them from manually working the wheel, but to work the wheel, they would have to offload the jack (make the elephant climb off) by relieving the elevator back toward neutral, but doing so pointed them at the ground, and that was that.
Here is a Youtube video presentation of the situation, filmed in a simulator:
Mentour Pilot: Boeing 737 Unable to Trim!! Cockpit video (Full flight sim)
    $\begingroup$ Reducing power so that the airspeed decreases, or not leaving power up so long that the speed increases unnecessarily, will also tend to remove the elephant. "Maintain aircraft control" is step #1, for runaway stab trim, and everything else. $\endgroup$
    – Ralph J
    Mar 8, 2022 at 13:33
    $\begingroup$ Problem is reducing power increases the pitch down, which is instantaneous, whereas the speed reduction takes time. And the speed reduction will require up elevator to sustain. They were boxed in once they let the stab movement go too far. The only way out was to let the airplane dive, not possible at a couple thousand feet AGL. Step #1 is disable the stab as soon as you possibly can. $\endgroup$
    Mar 8, 2022 at 13:58
    $\begingroup$ @Jpe61 improvements welcome! $\endgroup$
    Mar 8, 2022 at 13:59
    $\begingroup$ @abelenky IIRC problem was when they turned the electric trim on, they could only take out some of the MCAS input because the pilot trim rate is much slower than the MCAS rate, and when they stopped trimming MCAS would start driving again, so it was a case of 1 step forward, 2 steps back. If they had just disconnected right at the start before it went so far, they might have been ok with the stab shut off with the plane trimmed to 200kt instead 300 kt or whatever. $\endgroup$
    Mar 8, 2022 at 16:17
    $\begingroup$ @Cloud I would have to assess the failures in detail. But two things spring to mind. The media is generally wildly inaccurate in reporting, as anyone who reads media stories on topics in which they are expert knows, and, things on airplanes are breaking all the time, so occurrences that are relatively typical get hyped. There have been problems in the CRJ program that would make you avoid them forever if I hyped them up sufficiently, but the airplane is considered quite safe and reliable. Plus safe and reliable in transport a/c is at its worst many times safer than any other method of moving. $\endgroup$
    Mar 9, 2022 at 13:58
The core of this question and questions like it is based on a misunderstanding of a particular characteristic of the pitch control systems on the 737.
The general notion is that the yoke operates the flight control surfaces and the trim operates the flight adjustment surfaces. This would give the yoke pitch authority beyond that of the trim control, just like in most small aircraft.
On the 737 it's the other way around. The yoke still operates the elevator surfaces like in most other aircraft, but the trim controls adjusts the entire horizontal stabilizer, elevator surfaces and all. This gives the trim control system way more authority over pitch than the yoke, effectively turning it into the flight control system and degrading the yoke to the flight adjustment role.
The only way out of a runaway automated trim is by first disabling that automated trim control system and then manually readjust the trim control surfaces. Switching off the automated trim control system separately is for various reasons not possible. The only way to disable it is by switching off all powered pitch trim control. That includes the trim switch on the yoke. After that the readjustment of trim has to be done by turning the trim wheels ONLY.
At least one of the MAX crashes could have been prevented by simply keeping it that way. The fatal mistake was to repetitively reactivate the powered pitch control, thereby also reactivating the malfunctioning system. This not only makes the problem reoccur, but also makes it increase. That process repeats until the sheer authority of the trim control supersedes that of the elevator and the airplane goes into an unrecoverable dive.
The pressure problem arises as one pilot tries to maintain level flight by pulling the yoke, while the other pilot tries to adjust the trim wheels. These two forces work directly against each other. The harder one pilot pulls, the harder it is for the other to turn the wheel.
The solution is a roller coaster like routine that allows the spinning pilot to briefly adjust the trim wheel as the yoke pulling pilot briefly gives full slack. This decreases the problem with every turn of the wheel. This is by no means easy. Many experienced pilots still have a problem wrapping their head around it in unannounced simulations. It demands almost immediate response to something that occurs completely out of the blue and at first feels like ordinary turbulence.
The core of the story is that flight control input isn't always flight control authority and between automated pitch control and manual pitch control there is the switch on the yoke. It provides powered pitch control, which is neither automated nor manual.
A revealing part of the story is the fact that it shows how a 737,... correction, how any 737 can actually be trimmed straight into the ground. No pilot in his right mind would ever do that, but the intuitive notion that it's impossible is not correct. An intently obscured malfunctioning MCAS replacing a pilot who's not in his right mind proves that.
Meanwhile the impact of the MCAS related crashes continues to ripple through the aviation world. Reason for that is the one thing that everyone agrees on. These crashes should have been absolutely impossible, yet they happened. No NTSB investigation will ever determine the cause. No court case will ever convict those responsible. No FAA rule will keep it from ever happening again. Complacency is not reflective and mere ignorance does not provide closure. There's no excuse for these crashes, like there is no exception to what's impossible.
    $\begingroup$ Regarding "On the 737 it's the other way around." -> this makes it sound like the 737 is special in this regard, but it's actually not. Basically every transport category aircraft uses a THS (trimmable horizontal stabilizer). $\endgroup$
    – Bianfable
    Mar 11, 2022 at 7:32
  • $\begingroup$ @Bianfable The 737 is by no means unique in this respect, but the characteristic itself is not very common. It's the poor understanding of the consequence of this design, that caused the crashes. Nothing else.. $\endgroup$
    – user55607
    Mar 12, 2022 at 8:54
  • $\begingroup$ @Bianfable Look at your own comment. The term THS may be common use, but it is downright wrong. The actual thing trimming the horizontal stabilizer is the elevator surface. Altering the pitch of the stabilizer controls the pitch, but it doesn't trim it. That doesn't stop people from using the term, thus keeping the misunderstanding alive. $\endgroup$
    – user55607
    Mar 12, 2022 at 9:28
  • $\begingroup$ @Bianfable Applied with the proper redundancy and additional training, MCAS works just fine on the Max. MCAS should however never have been applied on the 737 as a non critical trim system, because on the 737 the trim isn't non critical.. Regarding this the 737 may not be unique, but it is special. The real ugly two crashes and hundreds of casualties so don't you ever forget that kind of special.. $\endgroup$
    – user55607
    Mar 12, 2022 at 20:22
  • $\begingroup$ " No FAA rule will keep it from ever happening again" - why is this? :( $\endgroup$
    – Cloud
    Mar 16, 2022 at 15:22
