Looks like a Kinner engine, appears to be a two person single cockpit. Resembles a Fairchild KR-21 and a Fleet type aircraft. Have not been able to locate any other similar aircraft, with these features, however gear and struts are different. Any ideas would be appreciated.
    $\begingroup$ Note the distinctive geometry of the long (black) strut of the landing gear-- this will be interesting-- $\endgroup$ Jan 26, 2022 at 12:39
    $\begingroup$ That gear geometry resembles a Meyers OTW, but those were dual cockpit trainers. $\endgroup$
    – Zeiss Ikon
    Jan 26, 2022 at 13:50
  • $\begingroup$ BTW, based on clothing, this is late 1930s or early 1940s, not a decade earlier. $\endgroup$
    – Zeiss Ikon
    Jan 26, 2022 at 17:30
    $\begingroup$ Important question: where did you get this picture from? $\endgroup$
    – Jpe61
    Jan 27, 2022 at 15:16
    $\begingroup$ *The photo is from a collection by Burton Bundy, who operated a flying service in the 1920's in San Louis Obispo, Ca and moved to Santa Barbara in the 1930's. Not certain when or where the photo was taken, which is also what I'm trying to determine. $\endgroup$ Jan 28, 2022 at 3:21
6 Answers 6
After gathering suggestions provided, I further researched the plane and discovered it in the 1931 Cal Poly Year Book. What I gather is the school had an aeronautics department and built 3 aircraft. One being a Warren Taperwing CP-3, which used an Arrow fuselage. The school made changes to the basic plane, as a way I suspect, to teach students about aerodynamics and aircraft structures. Specifically the 'balloon' tires were installed in lieu of bungee on the gear, for rough fields. It was registered as an experimental acft(NX10257) This then is a one off plane. The attached photo is from the year book.The original photo I submitted, must have been just prior to the planes' completion. The person in the photo is the wife of the owner of the plane. Thank you everyone for helping me to discover the identificationenter image description here
  • $\begingroup$ George, when I added that wikipedia link to your answer, I considered noting either in the text or as a comment to you that it did include a link to Warren CP-2 as a closely related aircraft, but no photos were provided. I had followed the link and noticed it said the plane was built on an Arrow fuselage, but didn't see the point in mentioning it since there were no photos, and since the plane in your photo seemed so similar to original Arrow in nearly all ways. Anyway you had probably already noticed that link yourself by that time. en.wikipedia.org/wiki/Warren_CP-2 . $\endgroup$ Feb 5, 2022 at 1:03
    $\begingroup$ So good job on hitting it out of the park this time! Now you really must "accept" this answer-- $\endgroup$ Feb 5, 2022 at 1:04
  • $\begingroup$ Yes without a photo I could not conclude this identification. However, the acft was just one piece of a puzzle I have been reservhing $\endgroup$ Feb 5, 2022 at 18:21
I believe this is a variant of the Fleet Model 1
The Fleet Model 1 (originally the Consolidated Model 14 Husky Junior) and its derivatives were a family of two-seat trainer and sports biplanes produced in the United States and Canada in the 1920s and 1930s
Note that there were various models, with the Model 7 being the first with a Kinner powerplant.
Another view of a Model 10, with a similar aspect to your original for comparison
Things that make me think this answer is right:
  • The geometry and shape of the balanced rudder
  • The semi-circular cut-out to the rear of the upper wing
  • Shape and location of struts and guy wires (although both were quite common in many models of biplane of the era!)
  • The engine cylinders exposed around the cowling (albeit this particular engine was used in a few, but not that many aircraft)
  • The general similarity between the look of the fuselage and its particular construction (especially the first picture above)
Things that cause me to second-guess myself, and that this might be the wrong answer
  • The odd strut going from undercarriage to upper cabane strut (Although as noted elsewhere, aircraft of this era were built with so many variants, and sometimes modified for a specific purpose such as rough fields which may have required bigger wheels and the strengthening of the undercarriage - could this be the reason for it? I was unable to find any picture with this modeification though)
  • The quite apparant different dihederal of the lower wing
  • This model of aircraft was primarily built as a two seater, and the original picture looks like it clearly has just a single cockpit.
  • The cowling looks too elongated in the original picture to be a Fleet Model (but again could this have been a modification?)
I think it is hard to be 100% sure this is the right aircraft as shown.
    $\begingroup$ @quietflyer you may well be right - it wouldnt be the first time I was sure I had the right identification and someone much more knowledgable comes along and proves me wrong. In my favour, there were a lot of variants of this particular model. $\endgroup$
    – Jamiec
    Jan 26, 2022 at 13:28
    $\begingroup$ The rudder, shape of the nose, wing cut out for the cockpit, wing struts, wing shape, fabric covered fuselage, engine and guy wires all lead to conclude this is a Fleet. The gear and single cockpit is still puzzling. The gear may be a post manufacture modification and I can check the approved changes of that era. If the forward cockpit was covered or deleted, it was done with great work, however, this may also have been one of the few manufactured with just a single cockpit. $\endgroup$ Feb 2, 2022 at 4:31
I have received suggestions from others, one of which most closely resembles the aircraft in the photo I submitted.....Arrow Sport. There were modifications made to the original design and variants were manufactured of the 100 total built. It is a single cockpit, two seat(side by side) design, which had two sets of controls for training purposes.
The issue with the rudder having a'horn' in my photograph and a number of Arrow Sport photos, that do not have a 'horn', is basically the only the major difference. A number of variants and changes were made through the early years and this may have been one. A couple of the modifications made included the outboard wing(N) struts and guy wires and engine types.
Here's a link to the Wikipedia page on the Arrow Sport.
  • $\begingroup$ The strut from the gear to the inboard N on the Arrow Sport looks very similar to the arrangement in your photo $\endgroup$ Feb 3, 2022 at 15:46
  • $\begingroup$ Tapered lower wing shows well in third photo in Wikipedia link, tapered upper wing is also somewhat evident. In upper wing it's pretty clear the taper is partly due to slightly swept leading edge, which may be at variance w/ photo in original question, or it may just be hard to see at that angle. This photo -- en.wikipedia.org/wiki/Arrow_Sport#/media/… . $\endgroup$ Feb 3, 2022 at 16:58
  • $\begingroup$ The long gear strut on all Arrow Sports has a faired rubber spring which is clearly missing in the airplane in question. I'm not convinced, but also have no idea what the plane in the picture is. $\endgroup$ Feb 3, 2022 at 17:27
  • $\begingroup$ The photo referenced in my previous comment also clearly shows the trailing edge of the lower wing, at the root, well below the bottom of the fuselage, as in the photo in the question -- one feature I failed to point out in my own "answer". The author of this answer might wish to consider incorporating some of these additional ID points into the answer. $\endgroup$ Feb 3, 2022 at 23:32
This is not meant to be a complete answer, but may help in the quest to find one-- it appears that the upper wing has some taper, i.e. the root chord (just outboard of the cutout) is significantly wider than the chord near the wing tip. Parallel lines should converge in the distance, and if you lay a ruler on the leading edge and trailing edge of the aircraft's upper left wing, those lines diverge, not converge, if you extend them far beyond the left edge of the photo. The taper appears to be entirely due to forward sweep on the trailing edge-- the leading edge appears to be unswept. I'm not seeing that same taper in photos associated with any answers posted up to this point.
A close look at the bottom wing suggests that similar taper may be present there too.
It also appears that both the top and bottom sets of wings have essentially zero dihedral, which also seems at variance with photos associated with answers posted up to this point. (The bottom wing may have just a hint of dihedral, but not much, no more than one or two degrees.)
Of course, it has been noted that some of these planes were produced in many variants.
A further note-- each of the main landing gear wheels is supported by three struts. The middle struts meet the bottom of the "cabane" struts, like on the Meyers OTW 160. The forward struts connect to the lower sides of the fuselage-- they don't meet together at the bottom of the fuselage as is the case with some other aircraft with rather similar landing gear geometry such as the Meyers OTW 160. Similarly, on the aircraft in the question, rather than meeting together on the bottom of the fuselage, the aft struts for the landing gear connect to the fuselage quite far apart, near the root of each the lower wings (and aft of the leading edges of the lower wings). The small white vertical rectangle above the aircraft's left tire is the aft strut for that wheel, highly foreshortened by the viewing angle, while the aft strut for the right wheel is more clearly visible in the photo, though its actual point of attachment to the fuselage near the wing root is hidden by the standing figure.
On first glance the photo gives the impression that two landing gear struts meet together, or cross in close proximity to each other, behind the standing figure, but that's not actually the case, and those two struts are not actually a matched pair-- they are the aft strut of the aircraft's right wheel and the forward strut of the aircraft's left wheel, and they are widely separated in the fore-and-aft direction.
    $\begingroup$ As for the comment on variants: worth noting also are the oddly wide tires. I'm certain this is a Fleet Model something, modified for soft/poor airstrips, hence the extra strut and the "offroad" tires. $\endgroup$
    – Jpe61
    Jan 27, 2022 at 16:56
    $\begingroup$ Partial answers are indeed fine, but you've just described the picture in the OP. I dont see how that answers the question, even partially. $\endgroup$
    – Jamiec
    Jan 27, 2022 at 17:37
    $\begingroup$ This does not provide an answer to the question. To critique or request clarification from an author, leave a comment below their post. - From Review $\endgroup$
    – Pondlife
    Jan 27, 2022 at 17:48
    $\begingroup$ @quietflyer great, but that's not an answer! $\endgroup$
    – Jamiec
    Jan 27, 2022 at 22:24
    $\begingroup$ @quietflyer I agree it's helpful to give pointers and suggestions to get to a better answer, and in the StackExchange world that's what comments are for. If we allow answers that don't answer the question and just make suggestions or even raise other questions then we have a discussion forum, not a Q&A site. SE is explicitly trying to avoid the discussion forum format. That's my take on it, anyway. $\endgroup$
    – Pondlife
    Jan 28, 2022 at 17:09
While this community has a huge knowledge base, and these kind of questions quickly attract precise and correct answers, I am not convinced any of the answers here, as they now stand hit the nail on the head, the answer by JamieC being the closest match IMO.
Just as JamieC, I'm quite convinced this is a representative from the Fleet Model 1 "family tree", but I'm certain this is a special one-off plane based on the following observations, "internet research" findings, and conclusions thereof. Most of these findings have already been posted in previous answers, but I'm relisting the here for consistency.
Fleet Model 1 family is by far the closest match to the overall posture and form of the plane in the picture. None of the Fleet Model 1 through 21 pictures I was able to find are a perfect match, but as Wikipedia states, variants of the Model 1 are numerous, including many one-offs. Other proposed planes differ substantially in such features as tailplane and fuselage cross section form, these are commonly quite stable design elements, and are seldom "fluid" among aircraft models.
The most notable differences for your garden variety member of Model 1 family are the lack of second seat, zero dihedral of the lower wing, extra landing gear strut and the oddly bulky tires. Smaller deviations are the deep cockpit cutout and elongated nose, latter may just be a visual misconception due to a wide angle lens.
Especially the single seat, landing gear assembly and the tire lead me to believe this is a special purpose plane, built for a pilot handling the plane rougher than usual, which lead me to this picture on aerofiles.com site:
Fleet Model 2 with Paul Mantz
The gentleman in the picture is one Paul Mantz, a prominent Hollywood stunt pilot, air racer and charter service provider. The thing that caught my eye was the tire Mantz is resting his foot on: clearly the same type shown in the picture at the question. Mantz used Fleet planes in his work as a stunt pilot, and it is not far fetched to assume he must have had connections with Reuben H. Fleet, the founder of Fleet Aircraft. This interaction may have spun off planes such as the one in the question.
One more thing suggesting a special purpose of this plane is the lack of dihedral in the lower wing. Biplanes are quite stable (in roll axis) due to the center of lift being high in relation to the center of gravity. Dihedral would further increase the stability, and this may not have been preferred by a stunt pilot.
A feature that puzzles me is the droop of the inner portion of the lower wing. Up untill now I have not been able to make sense of its purpose.
As for the picture itself, it is clearly not just a snapshot taken by someone wondering past a plane with his girl. There is artificial lighting in use, coming at least from two sources, the positioning of the plane is not "natural, as there seems to be no good reason for it to point in that direction other than that it forms the best composition with its surroundings being placed such. The lighting, composition and the wing ribs hanging on the wall make it clear to me much thought was put into setting up this picture.
The picture and the lady may be related to a movie of the era, for example on featuring Mantz as a stunt pilot (for a comprehensive list of Mantz's work, see IMDB). Closest match of actresses in these films might be Isabel Jewell, but this is a long shot. The picture may also be "just" a portrait; Phyllis Fleet, daugter of Reuben Fleet was an avid aviator, but she does not quite match the picture, being too tall for the timeframe. Mr. Fleet had two daughters from his second marriage, Dorothy and Nancy, neither of which are unfortunately traceable with means at my use.
And, to drift just one step deeper down the rabbit hole, one more possibility: Nancy Love was a famous WASP; Women Airforce Service Pilot, who has a link to a Fleet "frankenplane":
Love was hooked on flight at an early age. At sixteen, after just four hours of instruction, she flew solo “a rather broken down Fleet biplane that my barnstorming instructor imported from parts unknown.”
So in addition to being a poster movie, a personal portrait of a member of an aviation family, this picture may also have ties to the WASP program.
Getting back on track, the plane itself is most likely a model produced for a very specific purpose, be it show or stunt flying, racing or just a wealthy pilot's toy. Single seat biplanes are not exactly a common sight, and never were, not at least in civilian aviation. It also possible it may just be "prop", a non-flying showpiece put together of pieces of Fleet planes, but this seems a bit far fetched as all the technical details seem to be in order (aside from the lower wing dihedral).
Those with better (meaning non-internet, I've dug that inside and out) access to sources containing information about Mantz, the Fleet family saga and the original source of the picture, the collection by Burton Bundy will most likely be able to expound on this line of thought.
Take heed, I may expand this rant even further.
Given the relatively short list of aircraft for which the Kinner R5 family was an original or retrofit powerplant, and the very distinctive landing gear strut geometry, I'm pretty sure this is a Meyers OTW 160. The OTW were built with various engines; the 160 model had a 160 HP Kinner R5.
The only uncertainty is that the OTW line were, as far as I can determine, all built as dual cockpit trainers; it's very possible this one has had the front cockpit deleted or a very well matched cockpit cover fitted (cockpit covers, especially, were fairly common when the OTW were built, as they kept weather out of the front cockpit when the aircraft was tied down or when being flown solo).
As noted in comments, this aircraft type saw some minor variations over its production. Besides being sold with at least three different engines, there were changes in fin/rudder shape, some had fairings on the long struts above the landing gear while others didn't, I've found at least one photo showing a matching front cockpit cover, and while as noted in comments, the OTW has some dihedral in the upper wing, it was subtle enough to be hard to see from certain angles and positions.
(source: airport-data.com)
  • $\begingroup$ Those a/c appear to have at least a mild amount of dihedral in the upper wing, which I don't see in this photo. A good example where this shows is 4th photo down in this website aviation-history.com/meyers/otw.html . Note also very large rudder, and struts bracing horizontal stab to vertical stab -- $\endgroup$ Jan 26, 2022 at 15:33
  • $\begingroup$ Based on photos I found via Google, there were a number of minor variations -- not to mention four distinct models with different original engines (some of which were later re-engined with the Kinner). $\endgroup$
    – Zeiss Ikon
    Jan 26, 2022 at 15:38
    $\begingroup$ The Consolidated N2N-1 has 1. a more similar, curved upper wing cutout 2. a more similar tail brace cable 3. a more similar doubled up wing brace cable 4. faceted fuselage. I think none of the pictures posted yet show the right landing gear. $\endgroup$ Jan 27, 2022 at 15:12
  • $\begingroup$ I just noticed, that the front struts of the landing gear of the aircraft in the photo appear to meet the fuselage further apart on the sides, rather than joining together at the bottom of the fuselage as w/ these aircraft. $\endgroup$ Jan 28, 2022 at 10:56
  • $\begingroup$ @AnonymousPhysicist If you have a better answer, then please post a better answer. I started with a search on what aircraft had been built with Kinner radial engines, but it's entirely possible that almost any biplane in this size range could have been re-engined with a Kinner during the period when they were manufactured (or even after -- homebuilders fairly frequently install obsolete engines because they're inexpensive). $\endgroup$
    – Zeiss Ikon
    Jan 28, 2022 at 16:22
