What are all factors in design, excluding engine power and acceleration, thrust vectoring and flight computers, that makes a plane that have a real tight turning radius while maintaining speed? Like larger elevator, light weight etc. Where should the centre of gravity be placed? What are all aspects I need to know?
$\begingroup$ I'm not sure we have quite enough information here-- the answer might possibly depend on whether the "power loading" is ample, or modest? $\endgroup$– quiet flyerJan 23 at 23:13
$\begingroup$ Can we assume you want the plane to turn its path , not just rotate its orientation while moving in a straight line (as modern fighters can do) ? $\endgroup$– Carl WitthoftJan 24 at 15:40
1$\begingroup$ Can an airplane have one engine in full reverse thrust and one engine in full forward thrust? $\endgroup$– Vidyesh ChuriJan 24 at 16:11
In a turn you have two opposing effects: In order to tighten the turn, more of the lift needs to be tilted sideways for the needed centripetal force. At the same time, you want to fly slowly so the turn rate and with it the centripetal force stays manageable.
Starting with the equation for the turn radius: $$R = \frac{2{\cdot}m}{\frac{\rho}2{\cdot}c_{L}{\cdot}S} = \frac{v}{\omega} = \frac{v^2}{g\cdot\sqrt{n_z^2-1}}$$ you can see that radius $R$ is directly proportional to speed squared for the same load factor. Hence the desire to fly slowly. If you now plot turn radius in a Cartesian coordinate system with speed on the X axis and turn rate on the Y axis, lines of equal radius fan out from the origin like this:
Now there are two boundaries which determine where in this Radius-turn rate relationship an airplane can fly:
- Minimum speed at a given load factor (bold green line below), and
- Maximum sustainable load factor, which is limited by the structure and engine thrust (bold red line below).
Since compensation of the weight still needs some vertical component of lift (which explains the -1 in the denominator above), the green line creeps up to smaller radii as load factor increases (and the weight becomes less significant compared to the centripetal force). As soon as the airplane flies faster than minimum speed (the area to the right of the green curve), radius suffers.
This means the tightest turns are where the bold red and green lines meet. This minimum radius point can be shifted to smaller radii by:
- Lower wing loading. This will allow the airplane to fly more slowly.
- Higher maximum lift coefficient, for the same reason.
- Higher structural limits, so a higher load factor can be flown.
Of course, it must be possible to power the airplane at the minimum radius point and to trim the resulting pitch speed. Since engine power can be excluded here, the factors which help with a high pitch rate are:
- Low natural stability. The center of gravity should only be slightly ahead of the neutral point.
- Low stick forces over load factor, if you have manually operated controls.
- Short tail lever arm, which keeps pitch damping low.
If you have trouble to achieve enough thrust at the minimum radius point, try to increase wingspan in order to reduce induced drag. At this point induced drag has by far the biggest share of overall drag.
1$\begingroup$ "Maximum sustainable load factor, which is limited by the structure and engine thrust" And also by human biology. Pull more than about 10Gs, and the pilot isn't going to be feeling too good. This is important with high-performance fighter aircraft. $\endgroup$ Jan 24 at 11:41
$\begingroup$ @nick012000 At that g load, your engine will probably quit before the pilot does, if it is a jet. G loads for jet engines are quite strict - small deformations will already cause catastrophic failure. $\endgroup$ Jan 24 at 18:38
6$\begingroup$ @PeterKampf The reason they're designed that way is because there's no point overengineering a fighter aircraft to be capable of performing manoeuvres that will kill its pilot, so the fighters are designed to fail at the same time as their pilots do. $\endgroup$ Jan 24 at 19:50
$\begingroup$ @nick012000 As you can see from the graphs, higher gs quickly give you diminishing returns. It is more clever to make the structure less beefy, resulting in lower structural mass and lower wing loading, allowing the plane to fly more slowly. That is the best strategy for tighter turns. $\endgroup$ Jan 28 at 7:27
This generally means a short wingspan with an extra-strong wing spar structure (to take the lift and G loads), a wing with either high-lift devices that deploy in the turn or a relatively thick wing profile, no fuel tanks or excess mass in the wing itself (to minimize the axial moment of inertia of the airframe), big ailerons (to generate a large rolling moment), boosted controls (so a human is capable of working those big control surfaces) and a big engine (to maintain altitude & airspeed during the turn).
You'll find most of these design features in an aerobatic plane or a fighter.
1$\begingroup$ In general, keeping mass as close as possible to the centre of gravity minimises the moment of inertia so the control surfaces have less work to do $\endgroup$– FrogJan 23 at 19:21
1$\begingroup$ To be honest, those sailplanes have by far smaller minimum turn radii than any fighter due to their much lower wing loading. $\endgroup$ Jan 23 at 20:31
$\begingroup$ Wouldn't tanks (with fuel in them) in the wings help the wing to widthstand the load factor? Assuming the said fuel would otherwise be stored in the fuselage? $\endgroup$– Jpe61Jan 24 at 7:30
$\begingroup$ No, and if the wings held the fuel then the plane's roll rate would be slowed. $\endgroup$ Jan 24 at 7:33
