Fixed wing is a kind of heavier than air aircraft which uses fixed i.e. non-moving wings and other lifting services attached to the air frame and forward motion to generate lift. Examples include airplanes, gliders, powered lift aircraft, ultralights, powered parachute and weight shift controlled aircraft.
Rotary wing aircraft are heavier than air aircraft which generate lift by means of lifting surfaces attached to, and rotating about, a central shaft. They can either be under power and driven by an engine, or auto rotating in airflow moving through the rotor disk. Examples include helicopters, gyroplanes, and powered lift.
