I am currently studying both systems and I have the following doubt: why does DVOR rotate counterclockwise as opossed to CVOR? Could it be because the reference and variable signal are "swapped" between both of them?
  • $\begingroup$ Basically yes. What matters is how the two signals are rotated relative to each other. $\endgroup$
    Jan 13 at 8:16
  • $\begingroup$ So in this case, I can not understand how the signals can rotate relative to each other only variating the rotating direction $\endgroup$
    – A. R.
    Jan 13 at 8:25
