Is it legal in the United States to hire a test pilot to conduct the first flight(s) of a homebuilt ultralight? This seems like a bit of a grey area- FAR 103.1(b) states that an ultralight aircraft is a vehicle that “is used or intended to be used for recreational or sport purposes only” but I don’t see any reason that a pilot could not be paid to evaluate the flight characteristics of the aircraft.
  • $\begingroup$ Is this the first flight of a (factory built) ultralight? Or the first flight of a homebuilt ultralight? $\endgroup$
    – Ron Beyer
    Jan 8, 2022 at 1:40
  • $\begingroup$ A hypothetical home built ultralight. $\endgroup$
    – MD88Fan
    Jan 8, 2022 at 1:47
    $\begingroup$ It is legal as long as they are paid in bushels of wheat, or salmon. $\endgroup$ Jan 8, 2022 at 2:24
    $\begingroup$ If there is some kind of legality, don’t pay him for the flight. Pay him for his consultation before and after the flight. $\endgroup$ Jan 8, 2022 at 15:49
The FAA highly encourages you to find or hire a test pilot for your E-AB.
Advisory Circular 90-116
This advisory circular (AC) provides information and guidance on the Additional Pilot Program (APP) for flight testing experimental aircraft. The APP was developed to improve safety by enhancing Builder/Owner Pilot (BP) skills and mitigate risks associated with Phase I flight testing of aircraft built from commercially produced kits through the use of a qualified additional pilot and powerplant testing. The APP is an optional program which provides another pathway to conducting Phase I flight testing. The traditional option for a pilot to test their aircraft solo during Phase I is not covered or affected by this AC, and remains an option for those who choose to do so in accordance with their aircraft’s operating limitations.
Further on:
16. COMPENSATION. Compensation for the services of a QP or an OP may only be accepted or provided in accordance with the privileges and limitations specified by certificates held by the individuals.
This means in order to accept compensation, the test pilot must have at a minimum, a commercial license, appropriate medical, and be qualified to fly the aircraft. I'm not entirely sure if recent court rulings require a LODA though, you may want to check with your local FSDO.
    $\begingroup$ It looks like that document only applies to aircraft which have an "Experimental certificate issued under § 21.191(g), Operating amateur-built aircraft, or § 21.191(i)(2), Operating light-sport aircraft," but the question is about part 103 ultralights, which do not have airworthiness certificates. $\endgroup$ Jan 8, 2022 at 15:44
