10
The Beechcraft 1900, in addition to the usual wings and vertical and horizontal stabilizers, and the extra vertical tail surfaces added for improved directional stability, has a pair of horizontal tail surfaces, called "stabilons", on the sides of the rear fuselage (not to be confused with the 1900's actual horizontal stabilizers, which are mounted atop the vertical stabilizer in a T-tail configuration):
stabilons on two 1900Ds
(The stabilons of these two 1900Ds are circled in green to avoid confusion with the shadows of their horizontal stabilizers on the ground. Image by ERIC SALARD at Flickr, via russavia at Wikimedia Commons, cropped by Marc Lacoste at Wikimedia Commons, annotated by me.)
How, exactly, do the stabilons operate? Are they fixed structures? Do they move up and down to trim the aircraft? Do they move along with the elevators when the pilot commands a pitch input?
Not a dupe of this question or this question, neither of which discusses how the stabilons operate.
  • $\begingroup$ Lol it's like a horizontal version of the multi-tails on the Connie and C-2 Greyhound. $\endgroup$ Jan 2, 2022 at 0:14
  • $\begingroup$ Additionally, these aircraft have upturned winglets and... baby-sized hang-down vertical stabiliserettes (??) under the horizontal stablilisers. $\endgroup$
    – Criggie
    Jan 2, 2022 at 7:19
16
This Flight Safety Training Manual describes them as improving "deep stall" characteristics and C of G range.
The stabilons are fixed surfaces that add effective stabilizer area to improve the center of gravity range, and also, by their location, add that additional surface area in a low location that mitigates the tail blanking problem you get with T tails.
So they would have just increased the area of the existing stabilizer, but that didn't fix the stall issues which are inherent to the T tail. You could say that they added extra area as needed, and "de-T-ified" the configuration somewhat in the process by putting extra surfaces down low to provide a more positive pitch recovery than is provided by the existing T tail. A clever application of a band-aid solution that fixed two separate problems at the same time.
    $\begingroup$ For a deep stall the fuselage is too long - deep stall prone configurations have much less distance between wing and tail. But the low position of that additional tail surface is structurally advantageous, sitting at a point where its additional lift and mass can be carried by the existing structure. $\endgroup$ Jan 1, 2022 at 8:12
    $\begingroup$ The "deep stall" bit comes from the Flight Safety training manual that I linked to as my source., and I assume the writer got it from the OEM's engineering organization. In any case made some edits. $\endgroup$
    Jan 1, 2022 at 17:11
    $\begingroup$ Thanks for pointing me to the manual! On the same page they say that the T-tail puts the tail in undisturbed air - so the stabilons are in disturbed air? Reads a bit like written by marketing, not engineers. Still, they sure help to make a deep stall impossible. $\endgroup$ Jan 1, 2022 at 22:43
  • $\begingroup$ Wait, I thought horizontal stabilizers on the aft end subtracted from lift, providing downforce. Forward canards provide lift (and aren't blanked by the wings). $\endgroup$ Jan 2, 2022 at 0:20
  • $\begingroup$ The stabilizer/elevator system is generally subtracting lift FOR TRIM; that is, it will provide a net downforce to oppose an overall nose down pitching moment, as part of a balance of force system that drives the entire thing to want to align itself into wind at a specific angle of attack. For static stability purposes, this basic vertical weathervaning tendency, lift can be in either direction, depending on whether the "weathervane", the airplane's aerodynamic footprint rotating about its C of G, is on one side or the other side of its target alignment at any given instant. $\endgroup$
    Jan 2, 2022 at 2:09
They're fixed.
  1. The maintenance manual shows the rigging of the pitch/roll moving only the conventional elevators/ailerons.
  2. An Air Force Magazine issue—since it's also operated by the USAF under the designation C-12J—spells it out:
... auxiliary fixed horizontal tail surface (stabilon)...
For the general principle, see: How does an aircraft tailplane work? With the stabilon in the downwash of the main wing, this helps reduce the total lift per area of the combined tailplanes for more stability.
  • $\begingroup$ Is it in the downwash from the wing or upwash from the props? As these were made for cargo too (and also not podded jets), combined with the endcaps on the upper tail, the design indicates a need to avoid a stall due to rear CG placement. (but good references). $\endgroup$ Jan 1, 2022 at 1:51
