In the U.S., can a Student Pilot (Airplane-SEL) while training with an instructor and being the "sole manipulator of the flight controls," credit 3 takeoffs and landings to a full stop in accordance with 61.109 (a)(2)(ii), all completed between 1 hour after sunset and 1 hour before sunrise, towards meeting the night takeoff and landing experience (to carry passengers) specified in 61.57 (b)(1)(i) and (ii), as long as they were completed within 90 days of carrying the passengers and the pilot now has a PPL (Airplane-SEL)?
1 Answer
Yes, with the caveat that the flight is in the same category and class. Recent experience isn’t invalidated by the change in certificate. 61.57 (b) has two requirements listed in sub paragraphs:
(i) That person acted as sole manipulator of the flight controls; and
(ii) The required takeoffs and landings were performed in an aircraft of the same category, class, and type (if a type rating is required).
You have met the first. The presence of the instructor and the fact you are a student pilot are not relevant. The second is more than likely true unless you got your MEL certificate at or shortly after your PPSEL. In that case you could be night current in a single engine aircraft but not a twin (or the reverse if you got your private pilot in a twin and added SEL afterwards - not very common but possible.)
1$\begingroup$ I've added some info to the question to clarify a couple of points made in your answer. Thanks $\endgroup$– user22445Dec 24, 2021 at 20:42
1$\begingroup$ The answer is the same. As long as you as sole manipulator of the controls have the required 3 landings (to a full stop completed between 1hr after sunset and 1hr before sunrise) within the last 90 days, you’re good. $\endgroup$– GerryDec 24, 2021 at 21:00
1$\begingroup$ I totally agree with you. I just added to my question since you brought up those points, which I had omitted in the interest of brevity. This question is an outgrowth of an earlier question (somewhat different specific issue) that was closed as a duplicate to yet another question. See this linked question (and comments) : aviation.stackexchange.com/questions/90908/… $\endgroup$– user22445Dec 24, 2021 at 21:08
