Recently, Mexico's air safety rating was downgraded. How much more dangerous (in terms of statistical chances of fatal accident) is it to travel with a Mexican airline, than a European one?
    $\begingroup$ If you mean flying as a passenger on a commercial flight, your question really belongs on the Travel site. $\endgroup$
    – jamesqf
    Dec 1, 2021 at 18:35
    $\begingroup$ Why comparing with Europe? It is FAA who downgraded, not EASA. $\endgroup$ Dec 2, 2021 at 14:26
    $\begingroup$ @jamesqf Disagree, aviation safety and aviation regulations are both explicitly on topic here. Questions may be on topic on multiple sites and that's OK. $\endgroup$ Dec 2, 2021 at 19:34
  • $\begingroup$ @user3067860: If the OP was asking as a pilot, it would be relevant. As a passenger, it's not. If it's on topic, it shouldn't be. $\endgroup$
    – jamesqf
    Dec 3, 2021 at 3:12
    $\begingroup$ @jamesqf It specifically says that even aviation enthusiasts are allowed to ask questions. What would really change, though, if the question started off with "I am just about to start pilot training in Mexico next week..." and then continued exactly as written... Would it be on topic? Would the answer change at all? If the answers are "yes" and "no" in that order, then why discriminate based on who's hand was on the keyboard? $\endgroup$ Dec 3, 2021 at 16:41
11
To answer your title question with some numbers, here are the accident rates (number of accidents per million departures) for the world, Europe and Mexico from 2008 to 2020:
Accident Rates
(Data from ICAO - Accident Statistics)
It's not quite what you asked about since the ICAO data does not filter by airline origin country and the accidents might include non-fatal ones (but not incidents, see What is the difference between aviation "accident" and "incident"?).
Nonetheless, it's clear that Mexico is not significantly less safe than Europe. The average accident rate since 2008 was 3.27 in Europe, but only 2.06 in Mexico. The plot above should make it clear that these numbers are fluctuating quite a lot because of the small number of accidents in each year. For example, the large peak for Mexico in 2010 is the result of only 6 accidents. One should therefore be careful when deriving any conclusions from these numbers.
  • $\begingroup$ It's a good idea to provide these stats, but be aware the State criteria doesn't count accidents by operator State but by accident location. E.g in France stats Air France AF447 in 2009 (over east of Brazil) isn't counted while Germanwings 4U9525 in 2015 (over France) is counted. $\endgroup$
    – mins
    Dec 2, 2021 at 9:51
    $\begingroup$ @mins Yes, that's what I meant by "the ICAO data does not filter by airline origin country". Unfortunately, I couldn't find such a dataset. I found some with number of accidents by airline, but without a suitable denominator to get a rate, such a dataset is useless. $\endgroup$
    – Bianfable
    Dec 2, 2021 at 9:57
    $\begingroup$ Not disputing anything included in this answer, but it is very important to understand that reading stats and interpreting graphs is a whole science of it's own. To draw any conclusions, one has to be familiar with the subject in question, as well as how the stats were derived from data. Only thing that can be safely stated based on the graph above is that apart from 2010, flying is generally about as safe in Mexico as in the rest of the world. $\endgroup$
    – Jpe61
    Dec 2, 2021 at 10:59
    $\begingroup$ @Jpe61 Exactly, hence my last sentence. I would even go as far as saying in 2010 Mexico was just as safe as in the other years. It was just a statistical fluctuation. $\endgroup$
    – Bianfable
    Dec 2, 2021 at 11:39
    $\begingroup$ If there's anything that following US passenger rail has taught me, it's that the sample period has to be appropriate for the number of departures. Amtrak and the airlines used to trade safety crowns ... Amtrak was on top until Big Bayou Canot, then airlines were on top until 9/11. All this is inaccurate, and a very silly game, because the sample sizes are way too small and are whipsaw'd by single events. $\endgroup$ Dec 3, 2021 at 0:19
Short answer
Such audits are done by FAA to evaluate whether safety is correctly managed by the Mexican regulator in order to inform US DoT.
FAA found there is a problem in how Mexico is organized to supervise Mexican airlines, and consequently US DoT will prevent new Mexican carriers to enter the US market, freeze new routes creation, and will prohibit US carriers to sell seats on Mexican carrier aircraft, until this is fixed.
Nothing can really be drawn from the result. There are different domains evaluated, not being compliant in one domain is sufficient to be disqualified. FAA doesn't disclose the details of the non-compliance.
While this audit is performed by US for their own benefit, the framework used is the international framework of ICAO. ICAO also conducts audits in a continuous way. ICAO audit results can be viewed online with some details. Mexico was audited by ICAO in 2012. A comparison of results for Mexico (2012), US (2007) and France (2020, there is no "Europe" rating, ratings are by countries):
This comparison shows the Mexican authority is below the mean level regarding it's organization but also better than the US for licensing, legislation and operations.
How these categories are evaluated is described in the audit framework ICAO Doc 9734 part A: The Establishment and Management of a State Safety Oversight System (respectively §3.3, §3.6, §3.1 and §3.2). Exactly like ISO 9000 audits, both ICAO and FAA audits are related to the management system ability to detect and correct problems in carrier operations, they are not related to how airline actually perform their operations.
Bottom line: We don't know how Mexican carriers perform, we know they are overseen by a non-compliant regulator according to FAA, due to one or more unknown weaknesses.
Details related to obligations of ICAO members and audits follow for those interested.
Details
Chicago Convention: Obligations of the States
Mexico is a member of ICAO and signatory of the Chicago Convention. As such Mexico has legal obligations, which fulfillment is delegated by Mexico government to AFAC, the Mexican regulatory agency, counterpart of FAA for Mexico. Contracting States have safety-related obligations, in particular with art. 37 and 12:
(37): Each contracting State undertakes to collaborate in securing the highest practical degree of uniformity in regulations, standards, procedures and organization in relation to aircraft, personnel, airways and auxiliary services in all matters in which such uniformity will facilitate and improve air navigation.
(12): Each contracting State undertakes to adopt measures to insure that every aircraft flying over or maneuvering within its territory and that every aircraft carrying its nationality mark, wherever such aircraft may be, shall comply with the rules and regulations relating to the flight and maneuver of aircraft there in force.
Each contracting State undertakes to keep its own regulations in these respects uniform, to the greatest possible extent, with those established from time to time under this Convention [...] Each contracting State undertakes to insure the prosecution of all persons violating the regulations applicable.
ICAO audit: USOAP-CMA
ICAO members agreed on a continuous audit approach which abbreviation is USOAP-CMA (USOAP website) to evaluate how States fulfill their obligations. ICAO and FAA audits are based on the same reference, ICAO Doc 9734 part A: The Establishment and Management of a State Safety Oversight System, which includes 8 domains, either for rule-making or for rule-enforcement:
Audited domains under USOAP-CMA and IASA, source ICAO Doc 9734
FAA and IASA
FAA conducted their IASA in May 2021. Objectives, from FAA:
IASA assessments determine compliance with these international Standards by focusing on the eight critical elements of an effective aviation safety oversight authority specified in ICAO Document 9734, Safety Oversight Manual.
Those eight critical elements include primary aviation legislation; specific operating regulations; State civil aviation system and safety oversight functions; technical personnel qualification and training; technical guidance, tools and the provision of safety critical information; licensing, certification, authorization, and approval obligations; surveillance obligations; and resolution of safety concerns.
The results are the one you're talking about in the question. The fact that Mexico was found to be not compliant to ICAO standards, means they were found to have one or more of these problems (source):
  • Lack of advisory documentation;
  • Shortage of experienced airworthiness staff;
  • Lack of control on important airworthiness related items such as issuance and enforcement of Airworthiness Directives, Minimum Equipment Lists, investigation of Service Difficulty Reports, etc.;
  • Lack of adequate technical data;
  • Absence of Air Operator Certification (AOC) systems,
  • Nonconformance to the requirements of the AOC System
  • Lack or shortage of adequately trained flight operations inspectors including a lack of type ratings;
  • Lack of updated company manuals for the use by airmen;
  • Inadequate proficiency check procedures;
  • Inadequately trained cabin attendants.
Consequences from a FAA standpoint
From FAA:
While the new rating allows Mexican air carriers to continue existing service to the United States, it prohibits any new service and routes. U.S. airlines will no longer be able to market and sell tickets with their names and designator codes on Mexican-operated flights. The FAA will increase its scrutiny of Mexican airline flights to the United States.
Re-occurence
It is the second time that Mexico is in Category 2. The first time happened in 2010, and it took the government four months to regain its prior status.
Source
    $\begingroup$ It's not just that new Mexican carriers won't be allowed, it's also that existing ones can't open new routes to the U.S. and, perhaps more importantly, U.S. carriers can't sell codeshares onto the existing routes operated by Mexican carriers. This would be a pretty big deal for Delta, for example, which not only has Aeromexico as a close SkyTeam alliance partner, but actually owns a 49% stake in it. So, for example, they can't sell DL8XXX tickets on ATL-MEX flights operated by AM. Other Mexican carriers (e.g. Volaris, etc.) are also banned from opening new routes to the U.S. $\endgroup$
    – reirab
    Dec 2, 2021 at 22:17
  • $\begingroup$ @reirab: Good addition. $\endgroup$
    – mins
    Dec 3, 2021 at 14:58
    $\begingroup$ The airworthiness part is the most troubling, and clearly shows Mexico well below France and slightly below the U.S. $\endgroup$
    – Cloud
    Dec 3, 2021 at 16:13
