What does tendency of RVR (Runway Visual Range) mean and why down and up have the same values?
This is from AWOS(Automated Weather Observing System)
    $\begingroup$ that same value for up and down must be a typo! $\endgroup$
    – Jamiec
    Commented Nov 18, 2021 at 12:22
    $\begingroup$ can you provide a link to the document you extracted the table from? $\endgroup$
    – Federico
    Commented Nov 18, 2021 at 12:36
When included as part of the RVR, the tendency indicates whether it is trending up (improving), down (deteriorating) or there is no change. It is usually indicated by the suffix U or D.
When reported in a METAR it means that in the 10 minutes preceeding the observation, the mean RVR in the first 5 minutes varied from the mean RVR is the second 5 minutes by 100m or more.
An example would be R12/P1200U
  • Runway 12
  • Greater than 1200m
  • Improving
  • $\begingroup$ Thanks @mins I was really struggling to find something that matched my knowledge $\endgroup$
    – Jamiec
    Commented Nov 18, 2021 at 12:45
  • $\begingroup$ Thank you for your answer. Considering Metar, you're right. The message type in my case is awos not metar. So if the tendency value is 1 it means a tendecy exists, if 0 it means a tendency doesn't exist. $\endgroup$
    – mka
    Commented Nov 18, 2021 at 13:06
  • $\begingroup$ Better reference in ICAO Doc 9328: Table 11-2. Detailed structure of RVR information included in METAR and SPECI. $\endgroup$
    – mins
    Commented Nov 18, 2021 at 13:08
  • $\begingroup$ @mins that's the one I found, but as it was Chinese I wasnt sure it was a very good (ICAO) reference. $\endgroup$
    – Jamiec
    Commented Nov 18, 2021 at 14:06
