16
Large airliners display the amount of fuel in each tank as a mass (usually in kg or lbs) and not as a volume. This makes sense since mass is important for weight&balance considerations and the fuel mass is proportional to the amount of available energy.
Based on a discussion in the comments under this answer, I am wondering: how is the fuel mass measured?
On the Airbus A320 family, the fuel volume is measured via capacitance probes and then converted to mass by also measuring the fuel density:
The FQI [Fuel Quantity Indication] system calculates the fuel quantity based on values taken from probes in the tanks. The probes measure the level of the fuel in the tank, as a consequence of changing capacitance due to the amount the probe is immersed. This allows the determination of the fuel volume in the tank.
Yet the information that is needed by pilots is the quantity of fuel on board expressed as a weight. The translation of fuel volume into fuel weight is performed by the FQIC using the fuel density measured by specific devices in each wing tank [...]
(Airbus Safety First - Fuel monitoring on A320 Family aircraft)
The FCOM lists the sensors involved in this measurement:
The FQI system comprises : [...]
  • A set of capacitance probes in each tank to measure fuel level and temperature.
  • one densitometer (cadensicon) sensor in each wing inner tank permitting the calculation of the fuel quantity.
  • one Capacitance Index Compensator (CIC) in each inner tank giving the dielectric constant of the fuel in case of cadensicon failure.
(Airbus A320 FCOM - Fuel Description - Fuel Quantity Indication and Level Sensing)
Using the densitometer (or the backup CIC), the conversion from volume to mass is performed by the FQIC. The ECAM can then display fuel temperature and mass as calculated by the FQIC.
Additionally, there is an independent system sensing low fuel level, which would alert the pilots even if something goes wrong with the normal FQIS:
In addition to the sensors and probes feeding the FQI system, each wing tank is equipped with three independent dedicated low level sensors. These sensors are located in such a way that they become dry when the remaining fuel in the tank is approximately 750 kg. If two sensors in the same tank remain dry for more than 30 seconds, a low level alert triggers in the cockpit (fig.2).
The low level sensors are fully independent from the Fuel Quantity Indication, and are different in that they:
  • Do not provide pilots with a continuous indication of the fuel quantity in the wing tanks, but only the signal that the fuel level has reached below 750 kg (threshold crossed).
  • The information provided to pilots in the form of the low level alert results from a physical measure (sensors dry or wet) rather than from a calculation.
  • $\begingroup$ Pretty much all transport airplanes use capacitance systems. $\endgroup$
    Nov 3 '21 at 14:58
  • $\begingroup$ @JohnK Yep, that's what I read, too. The 777 seems to be an exception using ultrasonic sensors. But here I'm more interested in how they convert the volume to mass. That seems to be different between aircraft types. $\endgroup$
    – Bianfable
    Nov 3 '21 at 15:33
  • $\begingroup$ So in short, fuel mass is not measured, it is computed from volume and other factors. Just as you could compute the mass of fuel in your car's tank by knowing how many gallons/liters are in it, and the specific gravity of gasoline or diesel. $\endgroup$
    – jamesqf
    Nov 3 '21 at 17:42
    $\begingroup$ @jamesqf Exactly, except that the specific gravity is also measured in this case since it strongly depends on temperature (and of course also the type of fuel, like Jet A vs. Jet A-1). $\endgroup$
    – Bianfable
    Nov 3 '21 at 18:08
  • $\begingroup$ @Bianfable: Sure, just as the specific gravity of gasoline varies, too, depending on temperature, specific blends from the refinery, additives such as ethanol, &c. So it's much easier just to measure gallons, and a really dumb gauge that just shows fuel level. $\endgroup$
    – jamesqf
    Nov 4 '21 at 3:11
The 737 is the same as the A320 in principle (sensing filled volume then converting to kg or lbs for the crew).
From a 737 maintenance training manual:
Tank Units are hollow coaxial cylindrical capacitors mounted vertically to ribs inside each fuel tank. Fuel is used as the dielectric. The inner tube is profiled to correspond to the irregular shape of the inside of the fuel tank. The tank units are located throughout the tanks so an accurate reading is provided whatever the attitude of the airplane.
Here's an FAA drawing for such unit:
And indeed this sensor would be affected by temperature as Ralph has noticed, but it has nothing to do with directly sensing the mass or weight:
The use of tank unit capacitors, a reference capacitor, and a microchip bridge circuit in the fuel quantity indicators is complicated by the fact that temperature affects the dielectric constant of the fuel. [FAA; emphasis mine]
FAA source: FAA-H-8083-31A, Aviation Maintenance Technician Handbook-Airframe Volume 2 (via faa.gov's Aviation Handbooks & Manuals)
  • $\begingroup$ "The inner tube is profiled to correspond to the irregular shape of the inside of the fuel tank" Does this mean that the inner tube is of varying diameter to correspond with the shape of the tank, and not a smooth cylinder as depicted in the drawing? $\endgroup$
    – FreeMan
    Nov 3 '21 at 18:36
  • $\begingroup$ @FreeMan: My guess is varying coating or surface finishing, which would make manufacturing easier, but I don't know. $\endgroup$
    – ymb1
    Nov 3 '21 at 19:04
  • $\begingroup$ Interesting, I certainly didn't think of that, but it's not an unreasonable assumption. $\endgroup$
    – FreeMan
    Nov 3 '21 at 19:41
  • $\begingroup$ @FreeMan That’s the old way, FAA hasn’t rewritten their guides. On modern planes there’s a lookup table in the fuel quantity computer. This allows the same part to be used on all probe positions (a 737 has 12 per wing and 8 in the center) as well as across model variants and tank configurations (ER, HGW models) $\endgroup$
    – user71659
    Nov 3 '21 at 20:22
