1% (0.01 atm) of the sea level pressure is a bit less pressure than at the SR-71 Blackbird's highest altitudes. If all that atmosphere was 100% oxygen (instead of 21%), would a (sc)ramjet still be able to fly in it? If not, would it be able to fly in it if Earth's gravity was lower?
2$\begingroup$ Downvoter please explain why -1 so the question may be improved. $\endgroup$– Jpe61Oct 6, 2021 at 10:44
1$\begingroup$ @mins Alright I rephrased it so that it doesn't sound like more appropriate to space.SE. $\endgroup$– GiovanniOct 6, 2021 at 11:48
$\begingroup$ "This question does not show any research effort [...] or not useful". OP has not demonstrated they made any attempt at answering this question, and I don't see how this question is useful to the broader community. $\endgroup$– SanchisesOct 8, 2021 at 14:26
1$\begingroup$ @Sanchises You're right, I made an attempt to ask the question instead. What should I have done to answer it? The question and its answer should be useful to the OP in the first place. $\endgroup$– GiovanniOct 8, 2021 at 16:47
$\begingroup$ Do you mean, would the engine be able to operate, or would the aircraft be able to fly? VTC as unclear. $\endgroup$– Ralph J ♦Oct 12, 2021 at 17:14
Show 1 more comment
