12
The recent Oct 2021 YouTube video (The Insane Engineering of the 787 by Real Engineering) in the related question remarks:
[...] tiny doors whose purpose are a mystery to me with little to no information available online.
So, what is the purpose of those HLFC (hybrid laminar flow control) doors?
    $\begingroup$ Closer view. $\endgroup$
    – mins
    Commented Oct 4, 2021 at 7:36
14
— Sakurai, Seiya, and Matthew D. Fevergeon. "Door assembly for laminar flow control system." U.S. Patent No. 8,245,976. 21 Aug. 2012. [Current Assignee: Boeing Co.]
Each door is actually one door inside another, so they can open as a scoop, or an outlet (opening fore or aft).
During takeoff the door scoops in air, so higher pressure is created in the cavity behind the pores/holes at the leading edge of the vertical/horizontal stabilizer (shown above), so the pores would be cleaned of any contaminants. With the door open in the other direction, its purpose of boundary layer ingestion works by creating low pressure behind the pores; this drawing in of air at the leading edge "may decrease skin friction drag":
[...] when the first door is moved to the open position, the pores of the laminar flow control system may be purged by high pressure external flow captured by the first door and which may be ducted to the suction cavity for discharge through the pores. The discharge of flow through the pores may effectively remove contaminants such as liquid and/or debris that may be trapped in the pores [...]
When the first door is moved to the closed position and the second door is moved to the open position, a suction force may be generated in the suction cavity [...] the application of the suction force to the porous skin draws a portion of the boundary layer through the pores. As is know in the art, the drawing in or suctioning of the boundary layer may delay transition of the boundary layer to turbulent flow and may decrease skin friction drag.
— Ibid.
Of note, according to a nicely illustrated blog (in French):
[...] the future 787-9 and 787-10 will only be fitted with scoops on the fin and no longer on the horizontal plane, the gain being considered too low.
And, in 2015 the plan to have it on the 777X was dropped (aviationweek.com).
Unpainted system during testing; source: KSBD Photo at flickr.com (annotated)
Related: Why can't commercial aircraft have a wing boundary layer suction system?
  • $\begingroup$ Also this patent, by the same engineers. PASS = purge and suction system. $\endgroup$
    – mins
    Commented Oct 4, 2021 at 8:08
  • $\begingroup$ That second quote feels like it was written by lawyers. :( $\endgroup$
    – FreeMan
    Commented Oct 4, 2021 at 16:54
  • $\begingroup$ @FreeMan Yeah, pretty standard for a patent, since they usually are indeed written by lawyers, at least in part. :) $\endgroup$
    – reirab
    Commented Oct 4, 2021 at 22:07
  • $\begingroup$ For clarification, what does the PASS do for the aircraft? Obviously, it purges and suctions stuff... The quote reads, "The discharge of flow through the pores may effectively remove contaminants such as liquid and/or debris that may be trapped in the pores". What pores? What are they there for? Is this a whole new question? $\endgroup$
    – FreeMan
    Commented Oct 5, 2021 at 14:34
  • $\begingroup$ @FreeMan: No, that's a good request :) I've updated to include the location of the pores in text, and their general purpose. $\endgroup$
    – user14897
    Commented Oct 6, 2021 at 0:26
