How to find Radius/Rate of Turn given groundspeed and bank angle? Is GS/bank angle one of the formulas? What are the formulas needed for Turns Around a Point? I'm trying to find a way to explain this maneuver as if I was teaching a student pilot?
    $\begingroup$ Groundspeed needs wind information, or you must assume still air. $\endgroup$ Sep 25 '21 at 9:08
  • $\begingroup$ Good reading in addition of answers: FAA PHAK page 38 $\endgroup$
    – mins
    Sep 25 '21 at 18:08
Here are some equations - (pay attention how one changes the other - to visualize)
Radius of turn When speed doubles, radius increases by 4
$$ \text{Radius of turn} = \frac{v^2}{g \times \tan(\theta)} \qquad \text{(standard units)} $$
Rate of turn
If you increase speed, rate is smaller since you make a bigger turn
$$ \text{Rate of turn} = \frac{g \times \tan(\theta)}{v} $$
Hope this helps
The formula for Turn radius is $V^2 / G_R $, where $V$ is velocity (ground speed), and $G_R$ is radial G, which can be determined by taking the tangent of the bank angle multiplied by what G is in the units you are using for velocity (if velocity is ft/sec, then Gs must be in $\text{ft}/\text{s}^2$ ($\sim 32.2 \text{ft}/\text{s}^2$), or $\sim 9.8 \text{m}/\text{s}^2$). This is to ensure the numbers are all in the same scale.
So turn radius is $V^2 / \tan(\theta)$, where $\theta$ is the Bank Angle.
To get turn rate, just think about the velocity, and the circumference of a complete 360 degree circle. The circumference of a circle with radius $R$ is $2\pi R$, and if the velocity is $V$, then how long will it take the airplane to travel that distance? Time is distance divided by velocity. So it will take Time $T = 2\pi R / V$. And if it takes Time $ 2\pi R / V$ to go 360 degrees, then the turn rate is how many degrees it will change in one second, so that is $360^\circ V / (2\pi R)$.
But $R$ (from turn radius above) is $V^2 / \tan(\theta)$, so turn rate is $ 360^\circ V \tan(\theta) / (2\pi V^2) $, or,
Turn Rate = $ 180^\circ \tan(\theta) / (\pi V) $
NOTE. Again, to use these formulas everything needs to be in the same units: e.g., if V is in $\text{ft}/\text{s}$, then radial G must in $\text{ft}/\text{s}^2$. So in this case, using feet and seconds, you need to add $32 \text{ft}/\text{s}^2$ to the formula for radial G. Instead of $\tan(\theta)$, make it $32\times \tan(\theta)$. If you are entering velocity in knots, then the value of G must be converted to nautical miles per second squared.
    $\begingroup$ In your first sentence, I think you mean TAS instead of ground speed, right? Also, I converted the images to MathJax (Basic Tutorial and Quick Reference). $\endgroup$
    – Bianfable
    Sep 25 '21 at 17:33
    $\begingroup$ Depends on whether you want to know the Turn rate and radius in the atmospheric frame of reference (Moving with speed = wind velocity), or rate and radius across the ground. $\endgroup$ Sep 25 '21 at 18:12
