Let us say I am flying a twin-engine aircraft and I got a engine failure during cruise, without any control on rudder and use the ailerons only, can I still maintain the target track or heading? Will I got any sideslip?
  • $\begingroup$ You would need a pretty significant roll to counter the yawing effect of the dead engine... $\endgroup$
    – Ron Beyer
    Commented Sep 17, 2021 at 12:19
  • $\begingroup$ Without aileron you may not be able to maintain control, much less keep on your track. $\endgroup$
    – GdD
    Commented Sep 17, 2021 at 12:58
    $\begingroup$ @RonBeyer: According to this page, 8/10°. $\endgroup$
    – mins
    Commented Sep 17, 2021 at 13:15
    $\begingroup$ Why are you asking this question? Is there a particular reason you don’t want to use rudder? What type of “twin-engine aircraft” are you asking about? There is a big difference between a light piston twin with a 160hp versus a B777 with 115,000 lbs of thrust on one engine. $\endgroup$ Commented Sep 17, 2021 at 15:19
  • $\begingroup$ Are you asking whether you can maintain the SAME heading and track as before the engine failure, or whether you can maintain A heading and track? Because yes, you will be able to maintain a heading and track, but it obviously won't be the same! And of course you will have sideslip with an engine out and no rudder input. If you understand what sideslip is, and you know what a rudder does, why would you even ask such a question?! DV for asking a question where the knowledge indicated w/in the question is completely out of synch with what is being asked. (i.e. unclear, not useful) $\endgroup$ Commented Sep 17, 2021 at 16:37
What will happen is the airplane will yaw into the dead engine, with a certain amount of roll into the dead engine, depending on how strong the dihedral effect, the roll-yaw couple, is. A swept wing airplane will want to roll upside down and it will take lots of aileron just to keep it right side up.
A straight wing airplane with moderate dihedral effect will require some moderate amount of aileron to keep wings level, and with wings level you will find yourself in a flat skidding turn into the dead engine with some aileron applied in the opposite direction - as if you were flying with both engines and applied rudder with opposite aileron to get the same effect.
To stop the turn you will need to introduce side slip that offsets the lateral lift coming from the skidding fuselage, and this side slip needs to be induced by bank, so enough extra aileron will be needed to lower the wing into the live engine until the change in heading stops. You normally lower the wing into the live engine about 5 degrees even with rudder being used normally, but in this case it'll take a lot more.
You will now find yourself flying more or less straight, that is, not turning, but with the nose skewed toward the dead engine, and quite a lot of bank into the live engine, whatever it takes to stop the skidding turn. You will be all askew but more or less proceeding in a single direction and it will be more or less the same as if you just applied rudder with opposite aileron induced bank to stop the skidding turn caused by the rudder application.
Adverse yaw from the aileron application will aggravate the situation since the down aileron is on the dead engine side, so adverse yaw is helping the live engine. And obviously, more power aggravates the condition compared to less power and you might find that wide open throttle causes more skidding than can be offset with bank and you run out of aileron and are force to reduce power.
So it might take most of the aileron travel to maintain this configuration, and of course the drag is so high that if you are in a piston twin you may not be able to maintain altitude at any height, even if you have ample power, because you might be forced to reduce power to keep the thing from rolling over as you run out of aileron.
If you're in something like a Seminole at 5000 ft, you might be able to maintain level flight in that condition, maybe if down around blueline speed, but I wouldn't be surprised if the best that you can do is a shallow descent as you're forced to lower the nose to keep from stalling in that skewed profile.
If you're taking multi-engine training, there's only one thing to do; go try it and see what happens and report back here.
You can use ailerons in cruise, but it gets dangerous if airspeed decreases towards stall (aileron reversal and live engine will cause roll/yaw into the dead engine).
With ailerons there will be a slip towards the live engine, which helps counteract the yaw away from the slip. The configuration will very much resemble a forward slip, with the accompanying increase in drag.
As the plane is banked and side slipping, an increase in throttle and some nose up trim will also be required.
Depending on the aircraft model, additional rudder (more coordinated) may work better than ailerons alone.
  • $\begingroup$ The last paragraph shoud be deleted, as q defines no rudder rudder control. It is also somewhat misleading as it implies it is ok to fly some planes in sideslip during eo situations. It generally is not... $\endgroup$
    – Jpe61
    Commented Sep 17, 2021 at 15:53
  • $\begingroup$ You want to ensure you make it to a safe landing spot with minimal fuel consuption. Remember, enough fuel means you have time, and in emergenciens, having time is luxury. $\endgroup$
    – Jpe61
    Commented Sep 17, 2021 at 17:51
  • $\begingroup$ And after reading the reference by mins, I stand uncorrected. The question specifically asks about a situation " without any control on rudder". What I mean with the latter part of my previous comment: rudder input is necessary in eo situations (unless there is an automatic system providing it). I am unaware of multiengine acft that fly better without it. In engine out situations in multiengine acft you do not need to start lookin outside for spots to land, you check your map/gps for closest suitable airfield, and calmly proceed there, in an controlled manner. $\endgroup$
    – Jpe61
    Commented Sep 17, 2021 at 18:05
  • $\begingroup$ @jpe61 well, I'll settle for a better understanding, which you seem to have. Please keep in mind a pure aileron input will produce a slip. In this case a forward slip (asymmetric thrust does the "rudder" part, ailerons hold the course). As you correctly pointed out, the last paragraph does not address the question, but was added as a sensible alternative (coordinated) to handle the situation as per reference. $\endgroup$ Commented Sep 17, 2021 at 18:27
