10
I am intrigued by the white nose radomes on Russia's Sukhoi Su-30SM fighters. Why white?
Source
These white nose radomes are especially noticeable in naval Su-30SM fighters, as the latter are usually painted dark gray (1) — as shown in the photograph above. The Su-30SM fighters of the Russian Air Force are usually painted (light) blueish gray (2).
$\color{red}{\star}$ Why not paint the Su-30SM's nose radomes gray? Would the gray paint attenuate or reflect the radar emissions?
I searched online, but found nothing, unfortunately. Obviously, the information required to answer these questions may be classified. It seems that China's Su-30s have gray nose radomes, but I believe those are Su-30MKK rather than Su-30SM.
Lastly, do note that there's a similar question on Aviation SE asking why the Su-34 strike fighters have white nose radomes. I found that question on the Su-34 only after posting this question. I am not yet voting to close this question as a duplicate because I would rather not assume that the nose radomes of both the Su-30SM and the Su-34 are white for the same reason. They probably are, but I do not want to make that assumption.
References
  1. Телеканал Звезда, Полет нормальный: морская авиация ВМФ РФ отмечает 105 лет со дня создания, July 17, 2021.
  2. Zvezda, Combat Approved – Episode 19 – Su-30SM. With a stroke of the wing, 2015.
    $\begingroup$ That's a start of an excellent answer @mins. On a further note, Russkies are very efficient and resourceful. They may not have the latest technology or endles heaps of research funding, but they do all the little tricks that count. I bet my behind this white radome is one of them, as mins suggested. $\endgroup$
    – Jpe61
    Sep 11, 2021 at 18:02
    $\begingroup$ There are some with a black radome. So it's not the heat consideration. $\endgroup$
    – TomMcW
    Sep 12, 2021 at 1:25
  • $\begingroup$ Colors (well I guess black and white might not be considered colors as such, but anyway) come from pigment. The most common white pigment is titanium oxide (think we can disregard lead white here for obvious reasons), and black is either some sort of charcoal or iron oxide. Iirc the black (or bluish black) of A-12 and SR-71 was at least in part iron oxide. The pigments for sure effect the radar signals. How much, that would require some googling. $\endgroup$
    – Jpe61
    Sep 12, 2021 at 8:47
    $\begingroup$ ...and made of icecream :D $\endgroup$
    – Jpe61
    Sep 17, 2021 at 9:20
    $\begingroup$ @Jpe61 did you lick it to verify that claim? ;) $\endgroup$
    – jwenting
    Sep 21, 2021 at 8:54
10
+100
In short
White radomes are common in many applications, this is the logical choice, a white material reflects sun radiations which otherwise introduce electronic noise in the antenna.
Black radomes, only found in fast moving vehicles, owe their color to antistatic carbon powder used to eliminate electrostatic charges created by air friction. The replacement of black radomes by gray radomes is to hide radomes by lowering the sky/radome contrast.
The appearance of white radomes for aircraft is due to the fact satisfying white coatings have been found, they are used because they provide a better radiation protection than gray radomes. White conductive radomes combine all advantages but are more difficult to produce, and likely useful only for most sensitive radars.
On this aircraft, white radomes are found for the nose (radar), at the tips of the vertical stabilizers (VHF) and on top of the fuselage (satcom).
Constraints on materials
Materials for aircraft radomes must be resistant like other aircraft parts (pressure, heat, rain erosion) and must be electrically conductive to carry static charges, without significantly affecting waves to/from the antenna they protect. Coatings using conductive oxyds based pigments must be engineered in a way they appear like air to the antenna in the band of frequencies used, in order to not modify waves characteristics. This is possible but difficult as UV and rain make them instable. The stable ones are likely limited to the ones we see in use.
White / low noise is the best option for fixed installations
For fixed stations not degrading the antenna efficiency is most often the main concern and fixed radomes are white.
Sea-Based X-Band Radar
Sea-Based X-Band Radar, source
White reflects a large band of radiations from infrared to UV, both having negative effects.
  • IR is heat which can be eliminated by cooling, this makes the system more complex but is easily feasible. IR also creates additional noise both in the radome material and in the antenna. This reduces the radar performance. This effect cannot be offset, and when performance is critical, the only way is to reflect radiations to prevent them entering the radome.
  • UV degrade the material and change its dielectric properties.
Black is a better option for static charges elimination
Airborne radomes, specially at the nose, suffer another problem. At high airspeed, air friction ionizes the outer material. Charges accumulate if the material is not conductive and the radome becomes opaque to waves.
Metals are the best conductors, but they also block waves. Conductive radome materials or coatings are actually made of black carbon powder. This is the color we see since radomes are usually not painted to minimize signal losses.
F-16A Block 1
F-16A Block 1, source
Black is not the best option for radio noise, but has been necessary at a time to eliminate the more problematic static charges.
Gray is a good compromise for visibility and static charges
Black was found to have a significant drawback for a fighter: It increases the contrast over a clear sky, making the aircraft more visible. Conductive gray materials partially solve both the noise and visibility problems. From this page:
Because the black radome made the aircraft look like small black dots on white paper, the subsequent batches of F-16 switched to gray radomes.
The material could be a conductive black material receiving a very thin layer of gray coating specially crafted for the wavelengths used. Or the material could be gray and also conductive.
F-16AM Fighting Falcon
F-16AM Fighting Falcon, source: airplane-picture.net
Antistatic white radomes are better than gray for noise
Many antistatic coatings do not retain their properties under erosion from rain at high velocity and heat from friction. Their conductivity increases with time, affecting waves transmission. Stable white coatings are available, e.g. this white antistatic topcoat:
offering static charge dissipation capability and color tailorability as well as radar transmission consistent with current radome coating requirements.
They solve the visibility and electrostatic charges problems of military aircraft which was already covered with gray radomes, and in addition deduce the electromagnetic noise:
Su-27
Su-27, source
Civil aircraft radomes: Not as demanding as military radomes
Radomes for civil aircraft have been white or the color of the aircraft since a long time.
Antistatic material resisting heating is used. It can be painted in white or any color at the expense of some signal loss and boresight error, which are both acceptable for a weather radar (large targets) or ATC and satcom applications (limited path losses).
  • $\begingroup$ the black radome top on that F-104 has nothing to do with the properties of the material. It's to reduce glare for the pilot as compared to the white that the rest of the radome had. It had this because it was simply unpainted and the base material was white. $\endgroup$
    – jwenting
    Sep 13, 2021 at 8:05
  • $\begingroup$ It most certainly is NOT made of carbon fiber, which is opaque to EM radiation and would render the radar inoperable as well as being unsprayable as a PPG paint. The material data sheet linked in the answer lists an ingredient as carbon black, which is a powered form of carbon. $\endgroup$
    – Pilothead
    Sep 17, 2021 at 1:06
  • $\begingroup$ @Pilothead: You're right, it is carbon powder, not carbon fiber. $\endgroup$
    – mins
    Sep 17, 2021 at 7:38
I do not presume to know Russia's reasoning, but I think the following might still be helpful:
  1. Since at least the 70s any color became possible, compared to the conspicuous black of the prior years.
  2. White radomes offer extra protection against nuclear flashes.
So:
  1. Russia is using a simple solution (i.e. a uniform inconspicuous color across different liveries); and/or
  2. Protecting the radome against nuclear warfare.
Quotes and reference:
A white thermal control coating may be desirable for the outer surface of the radome to eliminate the small amount of ablation of the Duroid due to nuclear flash.
and
Until this latest development, anti-static coatings for radomes have used carbon black loading to dissipate static charges and therefore color matching of the coating to the airframe color scheme has not been possible.
Moraveck, J. F., and P. W. Sherwood. "New polyurethane coatings for radome applications." Proceedings of the 14th Symposium on Electromagnetic Windows, Georgia Institute of Technology, Atlanta. 1978. pp 3 and 153. (PDF via dtic.mil)
Naked (unpainted) nose in the 60s before the color developments; the rest of the airframe is painted in anti-flash white (thanks to @mins for finding the above interesting photo; wikimedia.org)
