KBOS has eight major runway ends:1 04L, 04R, 09, 15R, 22L, 22R, 27, and 33L.
As KBOS is primarily situated on (and occupies the vast majority of) a peninsula made by dumping lots of sand and dirt into Boston Harbor, and since making new land (especially new land that's going to be left completely unused except on the rare occasions that an aircraft goes off the end of a runway) is expensive[citation needed], only three of said eight major runway ends (22R and 27, which stop well short of the edge of the land,2 and 33L, which runs back up along the neck of the peninsula) are followed by full-size runway safety areas (RSAs):
KBOS
(via Google Earth) Yellow denotes RSA without EMAS; green denotes EMAS beds; red denotes neither.
KBOS's other major runway ends (04L, 04R, 09, 15R, and 22L) drop off into the ocean just past the end of the runway. As running off the end of a runway into the ocean is generally bad for non-seaplane aircraft[citation needed], this lack of RSA space would generally (in the U.S., at least) call for the installation of EMAS beds to catch aircraft overrunning these runway ends. However, only two of the five aforementioned runway ends (04L and 15R) are actually equipped with EMAS; runways 04R, 09, and 22L each have only a short, un-EMASed blast pad separating the runway end from the dropoff into the harbour.
This is especially worrying when one considers that 04R and 22L are two of KBOS's five primary instrument runways (and 04R is one of the airport's two ILS-III runways, the other being 33L) - i.e., two of the runways that the airport preferentially uses in the very weather conditions that lend themselves to runway overruns!
Why are only two of the five water-facing runway ends at KBOS equipped with EMAS beds to keep them from discharging aircraft into the sea?
1: All references here to "runway ends" refer specifically to the departure end of the runway(s) in question, since that's the end that aircraft tend to run off of.
2: And whose RSAs cross over each other not far past the ends of their respective runways, as seen here.
    $\begingroup$ Note that "runway safety area" refers to the protected area on either side of a runway as well as on each end. See AC 150/5300-13A for more information (check out paragraph 307 to start). $\endgroup$
    – randomhead
    Sep 5, 2021 at 1:22
  • $\begingroup$ @mins: According to the FAA Airport Master Record for KBOS, runways 04R and 22L each have shorter LDAs (8851 and 8806 feet, respectively) than 15R (9202 feet), and 04R goes right up almost to the edge of the water like 15R does. Yet, 15R has an EMAS, while neither 04R nor 22L does. And all of these are among KBOS's primary instrument runways - in fact, 04R is one of only two ILS-III runways at the airport (the other being 33L), meaning that, in the very worst weather conditions, one of the two available runways will be one (1/2) $\endgroup$
    – Vikki
    Sep 5, 2021 at 17:35
  • $\begingroup$ (2/2) ending in front of a drop-off into the harbour with no EMAS and hardly any RSA to speak of. $\endgroup$
    – Vikki
    Sep 5, 2021 at 17:39
    $\begingroup$ EMAS for RWY 27 end is planned for 2025/2026. Logan Runway 27 Runway Safety Area (RSA) Enhancements Project. Overall, interesting things in Logan 2018/2019 Environmental Data Report. $\endgroup$
    – mins
    Sep 6, 2021 at 11:00
    $\begingroup$ @FreeMan No, but they’re amusing. XKCD does that a lot. $\endgroup$
    – StephenS
    Sep 11, 2021 at 17:27
In 2009 it was determined[a] BOS needs one RSA/EMAS improvement. BOS had already built two small beds on its own dime in 2005/6, but due to the determination, the one needed improvement was replaced on an extended new pier:
Boston Logan International Airport (Boston, Massachusetts) must improve one RSA. This airport is constrained by Boston Harbor and urban development. As an interim measure to improving the RSA, the airport sponsor installed a partial EMAS (at its own cost) and is studying the possibility of installing a runway deck or filling in part of Boston Harbor and then installing a full EMAS. In addition, FAA’s regional office raised the maximum feasible improvement cost to over $40 million because the runway is used by Boeing 747 aircraft and was the site of a fatal 1982 accident. The airport sponsor has started assessing the project’s environmental impact and plans to complete the project by late 2013. (oig.dot.gov; 2009)
In 2019 it was determined[a] BOS needs another, which is to be constructed 2025–2026 (approval yet to be granted in Summer 2023):
Based on the 2019 FAA determination for this runway [9/27], the preferred RSA enhancement option for preliminary design and permitting will be construction of a 306-foot wide pile-supported deck (or pier) extending 650 feet from the existing runway threshold, with an EMAS installed on the deck. (massport.com)
Side note: Runway 09 is not used by jets for landing (source: a Massport RSA report and e.g. 2019 runway usage data), but the new bed of 2025/26 will improve the safety margins for rejected takeoffs (30% of jet departures).
a: Determination is based on a continual analysis, and when determined, there is no time frame to start the project:
AC 150/5300-13A:
Today, modifications to standards no longer apply to RSAs. The airport owner and the FAA must continually analyze a non-standard RSA with respect to operational, environmental, and technological changes and revise the determination as appropriate.
Order 5200.8:
A project to improve an RSA in accordance with the determination made in Paragraph 8 may be initiated at any time.
Similarly for SFO (San Francisco):
Southeast operations (operational assessment) are only less than 5% of the time:
Less than 5% of the time, aircraft follow the Southeast Plan, where planes take off to the east and land facing south. (flysfo.com)
Side note: Rejected takeoffs and undershoots are also important in RSA analysis (not just overruns). SFO's west operations (in use 95–98% of the time) utilizes the northeast water-facing direction for departures.
  • $\begingroup$ "SFO's west operations (in use 95–98% of the time) utilizes the northeast water-facing direction for departures" So, when the winds are from the west, KSFO has aircraft take off from the pair of runways that are a) shorter, b) worse-aligned with the wind, and c) cross over both the runways used for landing aircraft? It would seem to me like a better idea would be to use the runways that are a) longer and b) better-aligned with the wind for takeoffs, given that takeoffs are (for multiple reasons) more length-critical than landings. $\endgroup$
    – Vikki
    Oct 8, 2021 at 22:25
  • $\begingroup$ @Vikki: Noise and throughput are also factors; a) the perf calcs take into account the corrected length regardless b) e.g. Apr shows 11 kts avg wind (within most limitations) & the x-wind component doesn't impact perf c) ATC provides separation (intersecting rwys are used like that elsewhere, even for converging landings). $\endgroup$
    – user14897
    Oct 9, 2021 at 1:36
  • $\begingroup$ c) that relies on human skill to keep planes away from each other, and many many many many losses of separation, runway incurstions, or actual collisions have resulted from screwups on the part of controllers and/or pilots trying to maintain adequate separation. $\endgroup$
    – Vikki
    Oct 9, 2021 at 2:45
    $\begingroup$ @Vikki: It's not pure skill that varies from one controller to the other, rather training and procedures and equipment that take into account learned lessons; proposing not using intersecting runways because of human error (which is very rare to cause an accident), is like proposing not flying since most crashes are caused by pilot error (also statistically very rare to cause an accident). $\endgroup$
    – user14897
    Oct 9, 2021 at 2:54
