11
I am reading some regulations about vertical takeoff vehicles like a helicopter and there is some takeoff path is defined as below, and I am curious why there is a descent segment in its takeoff path? Is that a typical procedures that pilots pitch down to accelerate during takeoff? Vtoss: Takeoff Safety Speed? TDP: Takeoff Decision Point
  • $\begingroup$ Can you find descriptions of what the TDP and the VTOSS points represent in the diagram you pasted? Understanding those may provide some insight into what's going on with the various segments. $\endgroup$
    – Ralph J
    Aug 20, 2021 at 6:54
    $\begingroup$ Related: Why don't helicopters always takeoff from a hover out of ground-effect? $\endgroup$
    – Bianfable
    Aug 20, 2021 at 8:14
    $\begingroup$ Please share the source of your image. $\endgroup$
    – FreeMan
    Aug 20, 2021 at 11:46
11
These diagrams are used to depict the possible trajectories the helicopter can fly after a single engine failure. The pilot must ensure that there is sufficient obstacle clearance for that case.
This is for helicopters with multiple (i.e 2) engines. The take-off paths shown, are considering a failure of an engine at (just after) the take-off decision point (TDP). At engine failures before the TPD, the helicopter should be able to land safely at the final approach and take-off area (FATO).
Hovering and flying at low speed requires a lot of power. In case an engine fails during hover, the helicopter may not be able to accelerate forward while maintaining a positive vertical speed (i.e. climb). The optimal speed for climbing is the take-off safety speed, VTOSS. In order to transition between the hover and the climb at VTOSS, the pilot may need to trade height for speed initially. When VTOSS is reached, the helicopter can start to climb again.
The third diagram shows a vertical take-off in a confined area. In order to do so the helicopter need sufficient excess power available, even after a single engine failure. This usually limits the maximum take-off weight for such operations.
The horizontal distance between the TDP and the point that the helicopter starts climbing at VTOSS is called the take-off distance required.
    $\begingroup$ That whole "engine out" factor makes a lot more sense out of this! $\endgroup$
    – FreeMan
