I want to build a hydrofoil like this picture: enter image description here
I discovered that you can pump it with a leg motion and moving the center of mass. Like this:
I discovered xflr5 and did some of my own simulation. I am in aww of the complexity of aeronautic engineering. I learned so much in such a small time.
As you can see in the video, pumping is very hard and you can only do it for short amount of times. so that i had the idea to optimize the wing configuration for this type of drive. I am not quite sure if the rear wing produces lift or is actually pushing down like in a commercial aircraft. My design in xflr5 has a very high aspect ration and a very high wingspan and i am searching for designs with higher aerodynamic efficiency.
I found a few ideas:
  1. Flying wings i guess it would be hard to get longitudinal stability if the center of mass is so high.
  2. A canard wing configuration.
  3. Flying wing with bell shaped lift distribution
  4. Boxwing configuration
  5. Tandem configuration.
But i dont understand how tailless boxwing configuration produce longitudinal stability same for tandem configuration.
