Source: Shortest Landing!!! Severe Headwind! Aircraft hovers and vertically touches down! (YouTube)
What is this high-wing single-engine plane performing a short landing?
Sign up to join this communitySource: Shortest Landing!!! Severe Headwind! Aircraft hovers and vertically touches down! (YouTube)
The video description (thanks to ymb1 for adding the link) says:
By Jon Bush.
If you search for that name and STOL, you will find his YouTube channel, where you can find a higher quality video of that landing:
(Ultimate Alaskan Plane Landing, Zero Feet!)
The video description says:
Having too much fun flying this Experimental Stol Quest SQ12 supercub in the wind on the Knik River in Alaska @akbushpilot.
So the aircraft is an STOL Quest SQ12 Super Cub, an experimental plane based on the design of the Piper PA-18 Super Cub.
This is a Piper Cub which has been modified with a high-performance propeller and tundra tires. It probably also has either a 150 or 180 HP engine in it.
