All of the force things we talk about in aviation are mathematical constructs. All Aerodynamic forces, Lift, Drag, Induced or parasite, on whatever vector direction you choose, are constructs. The only real forces that an aircraft (or any body in a fluid) feels, are the forces exerted by the little molecules bouncing off the surface of the body. Each time a molecule hits the surface, and bounces off, there is a change in momentum, and a corresponding force exerted on the surface normal (perpendicular) to the surface, at that specific point where the molecule struck. All the constructs we talk about are just integral summations of all these tiny forces which are actually distributed over the entire airframe. We summarize them and pretend that an equivalent single force exists, which acting through a single point on the airframe (the aerodynamic center or AC), and chosen so that the actual effect of this constructed Psuedo force will be equivalent to the actual effect of the uncountable individual forces of all the molecular collisions discussed above.
Lift, Drag, etc. are just engineering psuedo forces chosen to add clarity or to allow engineering to perform calculations without having to deal with all the individual molecular forces, and get the same (or equivalent) results. Generally, Lift is chosen as the component of the actual aerodynamic Force which is normal or perpendicular to the aircraft flight path vector, and Drag is that component that lies parallel to the aircraft flight path vector.
Even the thrust of a propeller is in actuality, caused by the collision between air molecules and the cambered surface of the propeller, in the exact same way. Same with the thrust of a jet engine. It is caused by collisions of the high pressure combustion gasses on the turbine blades inside the engine. All the other formulae and shortcuts we use (like Bernoulli principle, or application of downwash comparisons for lift explanations), are accurate, not because they represent what is really going on, but because they take advantage of principles of physics like energy conservation of or momentum conservation.
