I have a question for BFR and Flight Currency.
Currently, I'm going to work for a small-sized local company as a First Officer.
and my last check-ride for COMM-MEAD (Commercial Multi Add-on) was 8th, AUG, 2019.
As far as I know, I don't need 'Flight Review' for at least 24 calendar months. (In other words, my flying can be conducted legally 31st AUG, 2021.)
and the training plan, which issued by our company, says we'll get a new type-rating for ERJ-145 on MID of JULY, 2021. (To be exact, I don't have type-rating for ERJ-145 yet. (but training has been completed. Only type-rating, that's the one of the missed item what I don't have yet.))
So I suppose, I don't need to take a 'Flight Review', because according to schedule, we'll get a new type-rating on MID of JULY, 2021.
Then After I get a new type-rating for ERJ-145 on MID of JULY, 2021, 'New period' for 'New 24 calendar month' will start from MID of JULY, 2021. so it will be valid for at least the END of JULY, 2023.
but the 'Company' says, still I need to do a 'Flight Review'.
Is there any one explain it clearly for me? Do I need to do a 'Flight Review'?
PS. the new type-rating for ERJ-145 will be a SIC privilege only.
    $\begingroup$ So the question is whether getting your SIC type rating counts as a “checkride” for BFR purposes? $\endgroup$
    – StephenS
    Commented Jun 27, 2021 at 23:40
CFR 61.56 states:
Flight review.
(a) Except as provided in paragraphs (b) and (f) of this section, a flight review consists of a minimum of 1 hour of flight training and 1 hour of ground training.
(d) A person who has, within the period specified in paragraph (c) of this section, passed any of the following need not accomplish the flight review required by this section:
(1) A pilot proficiency check or practical test conducted by an examiner, an approved pilot check airman, or a U.S. Armed Force, for a pilot certificate, rating, or operating privilege.
Typically Part 135 and 121 operators conduct annual proficiency checks of their pilots. Reference CFR 135.293 for an example of what is included in the requirements for a part 135 certificate holder to conduct a competency check of their pilots.
It should be noted that it references the generic term "pilot" as opposed to distinguishing between PIC and SIC. You will also note that these requirements are very similar to what is needed for a 24 month flight review. The FAA recognizes this, which is why 61.56 says that you don't need a 24 month review from a CFI if you have had a 12 month pilot competency check from a qualified check airman.
Therefore, per 61.56 you should be able to count 12 pilot competency check as your 24 month flight review for any personal flying you might want to do.
If you are asking us whether your company's check flight for the type rating also counts as their annual proficiency review, you will need ask your company directly.
  • $\begingroup$ The term is pilot proficiency check. I hope I'm not pulled over for running a light. "Officer", I say, "the light was green!". The officer responds, "the regulation simply uses a generic term "light" as opposed to "red or green light". Somehow, I think the words in the regulation matter. Just saying. $\endgroup$
    – wbeard52
    Commented Jun 30, 2021 at 3:16
  • $\begingroup$ Also note the term used is "pilot", not PIC or SIC... $\endgroup$ Commented Jul 1, 2021 at 16:05
§61.56 Flight Review
(a) Except as provided in paragraphs (b) and (f) of this section, a flight review consists of a minimum of 1 hour of flight training and 1 hour of ground training. The review must include:
(b) Glider pilots may substitute a minimum of three instructional flights in a glider, each of which includes a flight to traffic pattern altitude, in lieu of the 1 hour of flight training required in paragraph (a) of this section.
(c) Except as provided in paragraphs (d), (e), and (g) of this section, no person may act as pilot in command of an aircraft unless, since the beginning of the 24th calendar month before the month in which that pilot acts as pilot in command, that person has—
(1) Accomplished a flight review given in an aircraft for which that pilot is rated by an authorized instructor and
(2) A logbook endorsed from an authorized instructor who gave the review certifying that the person has satisfactorily completed the review.
(2) A practical test conducted by an examiner for the issuance of a flight instructor certificate, an additional rating on a flight instructor certificate, renewal of a flight instructor certificate, or reinstatement of a flight instructor certificate.
§135.293 Initial and recurrent pilot testing requirements.
(b) No certificate holder may use a pilot, nor may any person serve as a pilot, in any aircraft unless, since the beginning of the 12th calendar month before that service, that pilot has passed a competency check given by the Administrator or an authorized check pilot...
§135.297 Pilot in command: Instrument proficiency check requirements.
(a) No certificate holder may use a pilot, nor may any person serve, as a pilot in command of an aircraft under IFR unless, since the beginning of the 6th calendar month before that service, that pilot has passed an instrument proficiency check under this section administered by the Administrator or an authorized check pilot.
Flight reviews are for PIC rated pilots as stated in 61.56(c). First officers do not need a current flight review to provide SIC duties on airplanes they are qualified for under 61.55. For 135 operations, they need a competency check every 12 months.
A competency check (135.293) is different than a proficiency check and it does not constitute as a substitute for a flight review under 61.56(d)(1).
An instrument proficiency check (135.297) does count as a flight review under 61.56(d)(1).
The checkride for a SIC and PIC under 135 are different. If you are curious, you can find the minimum requirements for a SIC check in FAA order 8900.
Update to answer comments
Definition of competence
adequacy; possession of required skill, knowledge, qualification, or capacity Dictionary.com
the ability to do something successfully or efficiently. Bing
Definition of proficiency
the state of being proficient; skill; expertness: Dictionary
a high degree of competence or skill; expertise. Bing
The FARs do not define these terms and so common definitions are used. As of June 2021, there are 10 references to competency check and 45 references to proficiency check. There are no legal interpretations concerning flight reviews and competency checks or proficiency checks.
If the terms "competency" and "proficiency" are synonymous as suggested in the comments, there would be no reason for this verbiage in 61.55. The authors would have simply stated one term for 91k, 121, 125 and 135 instead or purposely separating out the parts for each check.
61.55 Second-in-command qualifications
(j) When an applicant for an initial second-in-command qualification for a particular type of aircraft receives all the training in a flight simulator, that applicant must satisfactorily complete one takeoff and one landing in an aircraft of the same type for which the qualification is sought. This requirement does not apply to an applicant who completes a proficiency check under part 121 or competency check under subpart K, part 91, part 125, or part 135 for the particular type of aircraft.
The only time a SIC and proficiency check are together in the FARs in is Part 121 and I am curious if that change was due to the 1,500 hr rule for airline pilot hiring.
All the other proficiency checks in the other parts are for pilot in commands. Competency checks are used for privileges as in 61.31 (e) and 61.31(f) as well a SIC competency checks for 91K, 125, and 135..
61.157(f). Flight Proficiency for ATP candidates a candidate can receive an ATP certificate after completing both a competency check and a proficiency check. Again proficiency for pilot in commands.
All of this logically leads to one conclusion. The authors of the FARs purposely differentiated between the terms competency and proficiency. They also purposely left out the term "competency" as a exception to the flight review requirements in 61.55(d)(1).
To further prove the point. A practical test for a certificate or rating requires both proficiency and competency. §61.43(a)(3).
Competency is a minimum standard to do a job. Proficiency is a much higher standard. I would prefer my doctor to be proficient instead of competent before he operates on me. Just saying.
  • $\begingroup$ This sounds like a good answer that might trump mine, but would you please post a quote, or page and paragraph reference that you are interpreting? (It is a big order.) I understand that part 135 and 121 PIC and SIC checkride requirements differ, but I don't think the boilerplate language "act as PIC" (on other aircraft that you are NOT limited to SIC...) is in conflict with my interpretation. Because 61.56(d)(1) uses the generic term "pilot" in regards to the proficiency check received as opposed to PIC or SIC. If they intended to exclude SIC checks they would surely have been specific. $\endgroup$ Commented Jun 29, 2021 at 0:23
  • $\begingroup$ @MichaelHall. That is a great question. See my updated answer. $\endgroup$
    – wbeard52
    Commented Jun 29, 2021 at 12:16
  • $\begingroup$ You haven't really expanded on why you are interpreting the regs this way: "A competency check (135.293) is different than a proficiency check and it does not constitute as a substitute for a flight review under 61.56(d)(1)." This is actually the exact opposite of what 61.56(d)(1) says! $\endgroup$ Commented Jun 29, 2021 at 15:30
  • $\begingroup$ Where in 61.56(d)(1) does it use the wording competency check? If a proficiency check and a competency check are the same, why does the regulations differentiate them? $\endgroup$
    – wbeard52
    Commented Jun 29, 2021 at 15:39
  • $\begingroup$ Good point. You are making a pretty conservative interpretation though. I think "competency" and "proficiency" are virtually synonyms, and may used interchangeably in this context, but I won't argue that point with you. I expanded my answer a little bit and stand by it. Let's see how the votes come in! ;) $\endgroup$ Commented Jun 29, 2021 at 17:17
