I am a new student and just need help understanding the fuel pump system. For a Cessna 152, in which scenario would I have the fuel pump on ?
Start ? After Start ? Before Take-Off ? After Take-Off ? Changing tank selection ? Stalls/Spins ? Approach and Landing ? After Landing ?
    $\begingroup$ I've never seen a 152 with a manually operated fuel pump, it's a gravity fed system with an enginne driven pump - you dont switch it on or off as such $\endgroup$
    – Jamiec
    Jun 19 at 9:56
    $\begingroup$ related (or duplicate if you remove the 152 detail): aviation.stackexchange.com/questions/21993/… $\endgroup$
    – Jamiec
    Jun 19 at 10:05
