Below is the link showing a fire fighting aircraft
From 0:23 to 0:45 an LED array can be seen. The peculiar thing about that is as aircraft approaches the site, all the LEDs are glowing, and vice versa when the aircraft leaves the site.
    $\begingroup$ The lights are for the tanker drop system. The individual lights indicate tank door status. Green means armed and ready to drop. This video shows the same type of aircraft doing a partial load drop with 4 tanks remaining full after the drop. youtu.be/oSC5PriYrI4 $\endgroup$ Jun 16 at 12:41
    $\begingroup$ The aircraft is an Avro RJ. I don’t see all the lights “glowing” as they depart. When they drop at 0:37 you can see all the lights flashing and then only they go out with a single green flashing on the right. (probably one door closing a little slow). As they climb away you see one solid green visible on the left side which is probably the system master light. $\endgroup$ Jun 16 at 13:18
  • $\begingroup$ Thank you Gentleman😊. $\endgroup$
    – vlad
    Jun 17 at 5:01
