I found on this website several questions speaking of IATA, ICAO and airports codes. The fact that two identification codes for the same airport exist means there are cases where you use one, and other cases where you use the other. I wonder what is the rule to know which code (IATA or ICAO) should be used.
$\begingroup$ Related: aviation.stackexchange.com/questions/8699/… $\endgroup$– Burhan KhalidMar 9, 2016 at 5:58
$\begingroup$ You may book a ticket with a travel agency to DLP, which is the IATA code for Disneyland in Paris suburb. However there is no ICAO code associated, because the park has no aeronautical activity and is not even close to an airport. $\endgroup$– minsJun 23, 2021 at 14:41
1 Answer
It helps to know the objective of both ICAO and IATA to understand when which code is used.
ICAO (International Civil Aviation Organization) is a UN-body which focusses on international harmonization of civil aviation regulations.
ICAO codes are used for "official" purposes such as Air Traffic Control; E.g. flight plans use ICAO codes for airports and airline flight identification.
IATA (International Air Transport Association) is a trade association that focusses on making air traffic businesses profitable, safe, secure, reliable and efficient.
IATA codes are mainly used for ticketing. E.g. travel itineraries use IATA codes for airports and IATA flight numbers.
2$\begingroup$ The IATA codes are 3-letter codes, since the number of commercial airports worldwide is enough that 3 letters are enough: DFW, LHR, NRT, etc. The ICAO codes cover more airports, so they're 4 characters with the first (USA) or first two (most of the rest of the world) describing the region, and the last two unique to the airport there: DFW (IATA) = KDFW (ICAO) {K=USA}, LHR (IATA) = EGLL (ICAO) {since EG = Europe/Great Britain), and NRT = RJAA (RJ = East Asia/Japan). Your ticket might say DFW-LHR, but flightplan is filed KDFW-EGLL. $\endgroup$– Ralph J ♦Aug 1, 2015 at 16:36
$\begingroup$ While pretty much all airports has an ICAO code, many smaller and non-serviced ones does not have an IATA. For example, look at small, unusual, high altitude airports. Basically, if they are marked on a flight map, it probably has an ICAO.With the obvious exception of countries/territories not conforming to int'l standards/rules. $\endgroup$ Feb 6, 2018 at 21:20
$\begingroup$ I don't buy this "different codes for different purposes" explanation. Both assign codes to the same things so this just seems like pointless and confusing duplication. $\endgroup$– xjclMar 29, 2019 at 18:42
$\begingroup$ Of note, in the USA: Terminal-area air traffic controllers prefer the FAA Location ID rather than the ICAO code. For airports with an IATA code, the FAA LID is usually (though not always) the same as the IATA code. $\endgroup$ Apr 24, 2021 at 4:48
