Why would a cargo pilot for example want to dump fuel to lower the stall speed? I understand that lowering the weight decreases the stall speed, meaning it is "easier" for the plane to reach this new lower speed and stall, correct? Why would I want that? Don't I want to have a higher stall speed so I could be far from stalling? What am I missing here.
  • 10
    $\begingroup$ A higher stall speed would mean you're closer to stalling because there's a smaller margin between the maximum speed (VNE) of the aircraft and the stall speed. $\endgroup$
    – MD88Fan
    Jun 11, 2021 at 11:45
  • 7
    $\begingroup$ " I understand that lowering the weight decreases the stall speed, meaning it is "easier" for the plane to reach this new lower speed and stall, correct? " -- not correct $\endgroup$ Jun 11, 2021 at 11:51
  • 7
    $\begingroup$ Are you aware that the stall speed is the minimum speed, not the maximum? $\endgroup$
    – DeltaLima
    Jun 11, 2021 at 16:29
  • 8
    $\begingroup$ STALL SPEED MORE = YOU HAVE TO FLY FASTER TO STAY AFLOAT. $\endgroup$
    – PapaMike99
    Jun 11, 2021 at 22:58
    $\begingroup$ It’s only easier to reach the lower stall speed if you’re starting from 0 (dead stop). If you’re already flying at given airspeed X, the distance from X to the new lower stall speed is greater, making it harder to stall. $\endgroup$
    – John Bode
    Jun 13, 2021 at 12:40
37
You have misunderstood.
Lowering the stall speed means that, whereas your stall speed at a given configuration was e.g. 150 knots, the stall speed now is 138 knots. This does not mean 'it is "easier" for the plane to reach this new lower speed'. It only means you can slow down more without stalling.
Moreover, keep in mind that dumping fuel lowers all associated approach speeds. Less weight means lower Vref , hence safer approach and landing (shorter landing distance).
  • 9
    $\begingroup$ and maybe the maximum allowed landing weight is lower than the actual weight with fuel. And you don't want to wait until all that excess mass is burnt off. Landing with more than the certified maximum weight is technically feasible, but requires a costly inspection afterwards. $\endgroup$ Jun 11, 2021 at 4:59
    $\begingroup$ Good answer. Lowering the stall speed would likely never be an important consideration and reason for dumping fuel (unless of really unusual circumstances). Normally dumping fuel is for the purpose of getting the aircraft down to max landing weight. $\endgroup$
    – user22445
    Jun 11, 2021 at 15:19
    $\begingroup$ @Peter Kampf How do stall speed decrease after decreasing weight? I think main purpose to dump fuel is to land with minimum weight. $\endgroup$
    – Auberron
    Jun 11, 2021 at 15:23
    $\begingroup$ @Auberron, although the question was not addressed to me, I could answer: "Stall speed increases as weight increases, since wings need to fly at a higher angle of attack to generate enough lift for a given airspeed". Source: aopa.org/news-and-media/all-news/2020/march/… The main purpose of dumping fuel, however, is indeed to land below the max landing weight. $\endgroup$
    – user12873
    Jun 11, 2021 at 17:21
Unfortunately this is incorrect. Aerodynamic stalls happen when an aircraft’s airspeed is at or below the aircraft’s stall speed for a specific configuration, attitude, phase and condition of flight. A higher stall speed will mean that you will be closer to stalling at any given airspeed. A lower stall speed is desired so that you can maintain a safety margin between your airspeed and the stall speed.
A lower stall speed also means the aircraft can fly and land at a lower airspeed and, in turn, ground speed. This would decrease its momentum, its required landing distance, and (in case of a soft field landing, off airport landing, or crash) its impact force with the ground.
“I understand that lowering the weight decreases the stall speed, meaning it is "easier" for the plane to reach this new lower speed and stall, correct?”
Unfortunately, the second half of this statement is incorrect. The different weight will produce different momentum, and a different amount of force required to change velocity. That does not mean that it will be easier or harder to reach a stall speed with a greater difference from the original flight speed than you would have had with the original stall speed. It just means that you may have to have a greater amount of acceleration to reach the lower speed than you would the higher speed in the same amount of time.
This is all irrelevant, though, since the entire point of lowering the stall speed is to make it harder to stall the aircraft. Especially at your given airspeed. Which means that they aircraft can fly at a lower airspeed without stalling. You do not want to stall the aircraft. This is important during low speed maneuvers such as approach, landing, and turns to final.
To put it in laymen’s terms, the stall speed is the airspeed at which the aircraft would stop flying. Another way to say it is that it is the airspeed at which the wings stop producing lift (or enough lift to keep flying). In reality, the stall speed is the airspeed at which flying straight and level would produce a high enough Angle of Attack that the airflow would separate from the wing surface. This is called the Critical Angle of Attack. Although it can be different for each aircraft, it is generally about roughly 17°. It also does not change for a specific aircraft in its configuration.
Lift is a function of: wing shape; airspeed; and the angle between the line formed by the relative wind and the chord line of the wing (Angle of Attack). Altering any of these would alter the amount of lift produced.
  • You alter wing shape with the wing control surfaces. The more camber you have, the more lift you will have.
  • You alter airspeed with power and pitch. The more airspeed you have, the more lift you will have
  • You alter AoA with wing load. The higher the AoA, the more lift you will have until it reaches the Critical AoA. The more wing load you have due to the forces applied on the aircraft’s mass (such as gravity and g-forces from turns and acceleration/deceleration), the more lift you will need to have to counter the wing load. And, the higher the AoA will need to be in order to produce enough lift to counter the wing load.
Reducing the weight which the wings have to carry (wing load) would reduce the amount of lift that must be produced. Reducing the wing load reduces the AoA that must be maintained to produce lift. The further away from the Critical AoA, the better and safer flight will be. The further away from the Critical AoA, the further you are away from a stall.
In the particular scenario brought by the Original Poster, this all may also be irrelevant. As pointed out by @Peter Kampf, dumping fuel to reduce weight may just be for the purpose of getting the aircraft below its Max Landing Weight. Or, in the case of an emergency landing, ridding the aircraft of as much flammable material as possible in case of a crash.
    $\begingroup$ Yeah, it's weird. Airplanes can land overweight, just need a more complex after-incident inspection. If I dumped 500 gallons of kerosene in a lake, and I told the authorities I did it to make a future inspection easier, I'd be in big trouble LOL! $\endgroup$ Jun 12, 2021 at 0:20
  • $\begingroup$ @Harper-ReinstateMonica: If you dump from high enough, it mostly evaporates on the way down, doesn't it? Unlike dumping "in a lake" where it's likely to to cause a localized problem. (At flight speed, the amount of fuel per volume of air is not huge, and it has thousands of feet to rain down.) Or am I mistaken, and this does lead to a rain of kerosene under the flight path? It's still a lot more spread out than most ground-based dumping, and I'm not sure what the authorities would have to say if you arranged to sprinkle kerosene into the wind from a tall radio mast by the lake... $\endgroup$ Jun 12, 2021 at 15:05
    $\begingroup$ Dumping fuel on an elementary school is never a good look: latimes.com/california/story/2020-01-14/… $\endgroup$ Jun 13, 2021 at 1:22
