I have seen this on all Boeing test planes, does this provide information on the planes performance?
1 Answer
That’s a trailing cone. It hangs out behind the aircraft and serves to calibrate the aircraft’s pitot-static system against static pressure error by providing a static source for ambient air pressure data in clean air well clear of the aircraft. The cone is connected to the aircraft by high-strength pressure tubing to feed the data to the aircraft.
