I need help identifying a plane from an older 1977 turkish comedy movie for a personal project, these are the best (and only) shots it can be seen.
Flyby flyby
Front Angle front angle
Close up cockpit outside close up cockpit outside
It is a Cessna 188 crop duster. The giveaway is the shape of the cooling air inlets on either side of the prop, which are "Cessna-shaped", as opposed to those on the similar Piper Pawnee which are rounded.
    $\begingroup$ Yep that's it nice catch. $\endgroup$
    May 9, 2021 at 18:44
  • $\begingroup$ This answer is a bit short but nevertheless correct. $\endgroup$ May 10, 2021 at 18:07
  • $\begingroup$ @PeterKämpf, detail added! -NN $\endgroup$ May 11, 2021 at 1:48
