I'm doing some research on enhancing wingtip vortices as part of my Honours project. After spending a fair bit of time in the literature and on this forum I have some models which should kick-start my simulations. Because this is such a under-researched field (understandably) I wanted to mine the wisdom of those here: What design elements for a wingtip geometry would be conducive to creating a strong wingtip vortex?
The context is that I am studying how to enhance the efficiency of autonomous formation flight, using one drone as the 'tug-boat' for the other trailing drone. The leading drone would be outfitted with vortex-enhancing wingtips in order to increase the upwash experienced by the trailing drone. The overall purpose is to increase the range of the secondary drone at the expense of the first, in situations like scientific aircraft stationed in Hobart anf flying round-trip to Antarctica.
So far I have identified the Aspect Ratio, Lift Coefficient and Oswald Factor as parameters I'll need to change, based simply off the induced drag equation $C_{d_i} = \frac{C_L^2}{\pi*AR*e}$. This has given rise to potential solutions like using vortex generators on the wing surface to enhance lift while removing the winglet to allow the flow to curl around the tip, pitching the winglet up to increase its local angle of attack (effectively the same principle), and using a wingtip fence that runs from the leading edge to half the chord length and stops there, creating a high-pressure difference and then allowing the vortex to develop rapidly.
I'm aware I may have fundamental issues with this theory but also that I don't know what I don't know. If this won't work physically, then an explanation as to what I should be focusing on to create greater upwash outboard of the trailing edge of the leading wing would be much appreciated.
