Does anyone recognize this round object under the belly of a PA-24?
From a Comanche parts catalog, it's the ADF loop antenna (item 45) minus the aero cover (30):
http://www.aeroelectric.com/Reference_Docs/Piper/pa-24-180-250-260-400_pcv1998.pdf
  • $\begingroup$ Thanks, especially for the link. I think I'll be referring to that a lot. $\endgroup$
    – Jeff
    Apr 26, 2021 at 16:15
That is probably the ADF loop antenna. To read properly, it must be installed so the little airplane's nose points in the direction of flight.
  • $\begingroup$ I dont have the long sense antenna (at least not on the exterior) which makes sense, since I dont have an operable ADF any longer. And the little airplane is facing the right way. $\endgroup$
    – Jeff
