B747 has a sweep angle of 37 deg and A380 has a sweep angle of 33 deg. If the main reason for sweep is to delay compressibility effects and increase operating Mach number, why does B747 cruise at a lower speed than A380?
$\begingroup$ This appears to only be true for the old 747 $\endgroup$– AbdullahApr 12, 2021 at 18:53
3$\begingroup$ @Abdullah: the econ crz speed of even the older 747 variants is faster $\endgroup$– user14897Apr 12, 2021 at 20:45
1 Answer
From Wikipedia, the cruise speeds of the both airplanes are fairly similar:
A380, nominal wing sweep angle 33.5 degrees, cruise speed Mach 0.85
Boeing 747: nominal wing sweep angle 37.5 degrees, cruise speed Mach 0.84 .. 0.9, depending on the model.
So those numbers would contradict the claim in your question, but align with your expectations. There are several other things to consider. The nominal cruise speed of these planes is more dictated by efficiency, required power for a given speed, and fuel prices. The 747 is an older design, when fuel was cheaper, the general tendancy is that modern airplanes reduced the cruising speed slightly in favor of higher efficiencies.
considering the sweep, raw numbers:
- cos(33.5 deg)= 0.83
- cos(37.5 deg)= 0.79
So the difference of approx 4% here seems to reflect the difference in cruising mach numbers: the higher sweep of the Boeing 747 reduces apparent Mach number roughly by the same amount that it is flying faster.
Then, for both airplanes, and certainly for the A380, the wing aspect ratio is quite low. So there's a point to challenge how much the sweep actually angles differ, from an aerodynamic point of view. It may be very well that effective angles depend a lot more on local airfoil shapes, low aspect ratios, and other 3d effects than they depend on the nominal sweep angle.
All that said, the swept wing has more advantages than just reducing the apparent Mach number. There is
- enhanced aerodynamic stability around the yaw axis (this may even help in the event of asymmetric thrust due to an engine failure)
- enhanced mechanical stability of the wing itself under aerodynamic loads
- trim properties in transsonic aero regimes
The final design is then a result of many different considerations. Eg, IIRC, the wing span of the A380 had a limitation so it would "fit into standard airports", and there were likely some trade-offs in aerodynamics for that reason.
